Injectors 1,5,7 aren’t firing - Ford Powerstroke Diesel Forum
 6Likes
post #1 of 22 Old 09-07-2019, 09:57 AM Thread Starter
Miles Kreh's Avatar
Quoted: 2 Post(s)
I just had all 8 injectors rebuilt, put new icp, ipr, glow plugs, UVCHs and oil change. I thought my injectors went out so i bought some remans and even after swapping known working ones in the 1,5,7 position they still will not fire. I have a GB reman 120v idm so I’m wondering if that could be the culprit. I’ve been trying to chase this issue for months and am starting to think I should maybe just drag her to a stealership and bend over. Any ideas appreciated.
Miles Kreh is offline
post #2 of 22 Old 09-07-2019, 10:52 AM
partyman97_3's Avatar
Quoted: 913 Post(s)
Garage
I am no expert on these, but just make sure all the connectors are snapped in tight. Maybe Corey will chime in. @[email protected]
2003 F-350, CC, LB, 285/75/16, Autometer Gages, Fox 2.0's (Thanks to Corey), Sninister Bypass Coolant Filter, 4" Turbo Back,Leece-Neville 230 Amp Alternator, 6.4 litre starter
partyman97_3 is offline
post #3 of 22 Old 09-07-2019, 10:55 AM Thread Starter
Miles Kreh's Avatar
Quoted: 2 Post(s)
@partyman97_3 yes I’ve made sure that they are plugged in correctly. I have the valve cover off right now and I’ve been trying to diagnose this thing for months. Even with brand new injectors I still get 2.9 ohms through the idm harness but 1,5,7 are still not firing. I appreciate the response of course.
partyman97_3 likes this.
post #4 of 22 Old 09-07-2019, 05:12 PM
greenskeeper's Avatar
Quoted: 302 Post(s)
How long have you run the engine since swapping injectors? It can take a while to get all of the air out of the oil system.
Gunga galunga...gunga -- gunga galunga.
97 F-250 CC 4x4 7.3L PSD E4OD 203K all original
99 F-250 CC 4x4 7.3L PSD ZF6 253K all original
greenskeeper is offline
post #5 of 22 Old 09-07-2019, 05:23 PM Thread Starter
Miles Kreh's Avatar
Quoted: 2 Post(s)
@greenskeeper about 60 miles with some wot pulls. It should be bleed by now. I replaced the injectors because 1,5,7 weren’t firing and they still aren’t.
post #6 of 22 Old 09-07-2019, 05:50 PM
Quoted: 530 Post(s)
Garage
3 is firing, but not 1,5,7? How are you determining this?
Swapping 3 with one of the other injector still only fires the same?
You could swap in a known good IDM from a friends truck -- the IDM is known to get water inside and cook the board -- but usually one whole bank or one even and odd pair fails
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #7 of 22 Old 09-08-2019, 06:04 AM
Quoted: 302 Post(s)
OK, I question that you were able to drive 60 miles with 3 injectors not firing at all....you'd be hard pressed to get the truck to do 20 mph on 5 cylinders.
Have you pulled the valve cover and confirmed that no oil is coming from those injectors while idling?
What speed are you able to drive the truck at?
Hydro likes this.
post #8 of 22 Old 09-08-2019, 03:45 PM Thread Starter
Miles Kreh's Avatar
Quoted: 2 Post(s)
@greenskeeper My shop is 30 miles there and 30 back. I drove it home, drove it back because it still wasn’t firing right and then I pulled the right valve cover and saw that 1,5,7 weren’t squirting oil out. I swapped #1 and #3 injectors and even after that the #3 cylinder injector fired. It has to be electrical since the problem doesn’t follow the injector.
post #9 of 22 Old 09-08-2019, 03:46 PM Thread Starter
Miles Kreh's Avatar
Quoted: 2 Post(s)
@greenskeeper I could hardly manage 50
post #10 of 22 Old 09-09-2019, 11:15 AM
Patrick Feeley's Avatar
Quoted: 87 Post(s)
I would do the tests of TB 103: 1994-03 Ford 7.3L IDM Replacement & Diagnostics if you haven't already done so. Have the VC harness pigtails been replaced? If so are they wired correctly? Cheers!
[email protected] likes this.
Patrick Feeley is offline
