Injectors 1,5,7 aren’t firing - Page 2 - Ford Powerstroke Diesel Forum
 6Likes
post #11 of 22 Old 09-09-2019, 01:49 PM Thread Starter
Miles Kreh's Avatar
Quoted: 2 Post(s)
@Patrick Feeley yes I have seen that procedure before. I’ve done that test and every injector reads out to 3.0 and the other wires are open. I have not replaced the pigtails because they are in good shape but I have a couple replacements somewhere.
Miles Kreh is offline
post #12 of 22 Old 09-09-2019, 05:31 PM
Patrick Feeley's Avatar
Quoted: 79 Post(s)
Not suggesting you replace them, just wondering if the wiring is in the correct order. Are the UVCHs OEM? There have been reports of some aftermarket ones being wired incorrectly. Cheers!
Patrick Feeley is offline
post #13 of 22 Old 09-09-2019, 05:35 PM Thread Starter
Miles Kreh's Avatar
Quoted: 2 Post(s)
@Patrick Feeley Yes the UVCHs are brand new motor craft parts. I’ve made sure that everything important has been oem. Is there any way to check the idm? I’m just totally stumped what could cause 1,5,7 to missfire but not 3.
post #14 of 22 Old 09-09-2019, 05:37 PM Thread Starter
Miles Kreh's Avatar
Quoted: 2 Post(s)
@Hydro are the aftermarket idms known to go bad? I have a 120volt reman one that’s relatively new. It was replaced about a year ago from the guy who owned the truck before me.
post #15 of 22 Old 09-10-2019, 10:30 AM
Quoted: 79 Post(s)
I would guess its the IDM, but Ö.. If you know of someone with a known good IDM, maybe try that one. Years ago I bought 2 IDMs off ebay for $50 each. They are my spares in the toolbox. Cheers!
[email protected] likes this.
post #16 of 22 Old 09-10-2019, 09:34 PM Thread Starter
Miles Kreh's Avatar
Quoted: 2 Post(s)
@Patrick Feeley I bribed a buddy to let me borrow his idm by helping with the 3 inch downpipe conversion. That was worse than I remember. Anyway my truck acted the same if not worse with his idm and his truck ran perfectly with mine. I’m completely stuck. The pcm has corrosion on it but not on any of the internals. Idk at this point
post #17 of 22 Old 09-11-2019, 10:44 AM
Quoted: 79 Post(s)
That is really puzzling! If it is not the IDM (which looks like you have ruled that out), and the injector wiring is good end-to-end, I would probably look for another PCM to try. What year truck and transmission do you have? Cheers!
post #18 of 22 Old 09-11-2019, 11:26 AM
partyman97_3's Avatar
Quoted: 888 Post(s)
Garage
Maybe Sean will chime in. He is our resident 6.0 guy, but he will know the 7.3. @LoxDiesel
2003 F-350, CC, LB, 285/75/16, Autometer Gages, Fox 2.0's (Thanks to Corey), Sninister Bypass Coolant Filter, 4" Turbo Back,Leece-Neville 230 Amp Alternator, 6.4 litre starter
partyman97_3 is offline
post #19 of 22 Old 09-11-2019, 01:49 PM
Quoted: 12 Post(s)
I had a similar problem and found the harness from the main connector to the valve covers to be the culprit. I unwrapped each side and found wiring that was oil soaked and the insulation just about all gone on 3- 4 injector wires. Cut the bad wire out and solder new wire in. Do one at a time as not to get things wired wrong. The drivers side was worse as the pcv elbow was hard and leaking oil onto the harness. It will take a couple of hours to do it right but once complete, problem solved.
PDR60 is offline
post #20 of 22 Old 09-11-2019, 01:51 PM Thread Starter
Miles Kreh's Avatar
Quoted: 2 Post(s)
@PDR60 That’s what my teacher told me to check. I’m about to go take a look at it.
