7.3 No start, No smoke after injector install - Ford Powerstroke Diesel Forum
 23Likes
post #1 of 17 Old 08-27-2019, 12:57 PM Thread Starter
Miles Kreh's Avatar
Quoted: 2 Post(s)
I have a 1996 7.3 that will not run. I’ve ohmd the injectors and they all read 2.9, I’ve filled up my hpop, done a buzz test, checked and cleared all codes, has 50 psi at the valve and just put a new fuel filter in it. Oil is brand new with a new filter. It will run with a gas soaked rag over the intake. I’ve killed my batteries probably 10+ times now cranking, making sure it doesn’t go under 10.5 volts. I have a snapon Zeus scanner which can read sensor data. My icp was reading zero which I think is incorrect because of the amazon sensor I threw in it so with that unplugged it reads 2440 icp and 36%ipr when cranking. It also gets around 180 rpm on the starter. I checked the harness going to the valve cover and it wasnt sending it any voltage but I used a digital volt meter. Tomorrow I will use an analog one. Any info appreciated, I’m only 17 and this is my school project of sorts (I go to a tech school). My teacher is a old ford tech and knows a lot about the idi engines but he left the dealership right when these things came out.
[email protected] likes this.
Miles Kreh is offline
post #2 of 17 Old 08-27-2019, 02:10 PM
SparkyF250's Avatar
Quoted: 3258 Post(s)
Garage
@[email protected] @LoxDiesel either of you guys got anything for this young man? My kid's going to diesel tech school too, like to see him figure it out.
partyman97_3 and Miles Kreh like this.
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is offline
The Following 2 Users Say Thank You to SparkyF250 For This Useful Post:
Miles Kreh (08-28-2019)
post #3 of 17 Old 08-27-2019, 02:29 PM
Corey@CNCFAB's Avatar
Quoted: 1406 Post(s)
Feedback Score: 4 reviews
Your scanner is not wrong on the ICP reading with it plugged in, you have a High Pressure Oil leak somewhere. 2440 is a default number the computer gives when the ICP is unplugged.
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
post #4 of 17 Old 08-27-2019, 03:45 PM Thread Starter
Miles Kreh's Avatar
Quoted: 2 Post(s)
I thought that if there was a leak somewhere I would get some icp pressure even if very little. Also what could cause the injectors from getting the voltage from the idm?
post #5 of 17 Old 08-27-2019, 03:46 PM Thread Starter
Miles Kreh's Avatar
Quoted: 2 Post(s)
Also my oil pressure on my dash is where it normally is when cranking
post #6 of 17 Old 08-27-2019, 04:55 PM
Love all, Trust a Few...
LoxDiesel's Avatar
Location: If you go West and hit sugar cane come back a bit
Quoted: 1091 Post(s)
How did you seat the injectors? 7.3ís are a little tricky, I have to use a rubber mallet to get them home before torquing the bolt. If you have a hydraulic shop handy you can rig up an air chuck with a whip to each cylinder head and see if they hold air. Pressurize where the hpop hose hooks up. You sure ipr is plugged in?
Sent from my iPhone using Tapatalk
Patriot, SparkyF250 and Miles Kreh like this.
@loxdce
LoxDiesel is offline
post #7 of 17 Old 08-27-2019, 05:19 PM
SparkyF250's Avatar
Garage
OK @Miles Kreh you have two shop owners here to help. Listen to them and do what they tell you.
Miles Kreh likes this.
Sparky
post #8 of 17 Old 08-27-2019, 05:46 PM Thread Starter
Miles Kreh's Avatar
Quoted: 2 Post(s)
@SparkyF250 I am not questioning their experience I just want to know as much about how this truck works as possible since I plan on keeping it for a while. I can’t try anything until around noon tomorrow because it got towed to my shop at school. I really appreciate the quick responses by everyone and sorry if I seem a bit nosy with advice.
SparkyF250 likes this.
post #9 of 17 Old 08-27-2019, 05:53 PM Thread Starter
Miles Kreh's Avatar
Quoted: 2 Post(s)
@LoxDiesel I seated them by hitting the tops of the solenoids with a rubber mallet then torqued the retainer bolts to spec. We will check if the head holds pressure tomorrow.
Patriot and SparkyF250 like this.
post #10 of 17 Old 08-27-2019, 05:55 PM
SparkyF250's Avatar
Garage
Originally Posted by Miles Kreh View Post
@SparkyF250 I am not questioning their experience I just want to know as much about how this truck works as possible since I plan on keeping it for a while. I canít try anything until around noon tomorrow because it got towed to my shop at school. I really appreciate the quick responses by everyone and sorry if I seem a bit nosy with advice.
Just sayin Corey and Sean are both shop owners and know the 7.3 as well as anyone. They will help you, don't be afraid to ask questions, that's how you learn. Also be aware since they are shop owners, they're busy so they may not have an immediate reply. Another good source of info is our "librarian" @djmaguire he's pretty good on the electric side of things.
Patriot and Miles Kreh like this.
Sparky
