Crank no start 97 7.3 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-19-2019, 11:16 PM Thread Starter
I have a 1997 F250 that started to idle rough and shut off like I turned the key off and wouldn’t start again. I replaced the cps, icp, ipr, has a new fuel filter and is getting fuel. When it first happened the truck was towed to a shop and hooked up to a scanner witch showed no codes. I don’t know where to look next, any help would be great.
Maxminor is offline
post #2 of 5 Old 07-20-2019, 09:08 PM
Patrick Feeley's Avatar
Quoted: 85 Post(s)
Does the Wait-To-Start light come on normally? Check the oil level. What's fuel pressure when cranking? Minimum is 25 psi at 100 rpm minimum crank speed. Cheers!
Patrick Feeley is offline
post #3 of 5 Old 07-20-2019, 09:10 PM
Quoted: 326 Post(s)
Check ALL fuses
White95f250 is offline
post #4 of 5 Old 07-21-2019, 08:31 PM Thread Starter
The wait to start light comes on, oil level is good, I’m not sure on the fuel pressure while cranking. I’ll have to check fuses and pressure on Tuesday when I get a chance to work on it.
Maxminor is offline
post #5 of 5 Old 07-26-2019, 10:36 AM
greenskeeper's Avatar
Quoted: 300 Post(s)
cooked UVCH ? Remove the oil cap and give it a sniff...smell burnt wiring?
Gunga galunga...gunga -- gunga galunga.
97 F-250 CC 4x4 7.3L PSD E4OD 203K all original
99 F-250 CC 4x4 7.3L PSD ZF6 253K all original
greenskeeper is offline
