Motor surging at start - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By 1Dieselman
post #1 of 8 Old 05-01-2019, 06:09 PM Thread Starter
Quoted: 4 Post(s)
Hey guys I have a 96 f350. When I crank it, it surges until I apply throttle a little then stops... then does t happen again till I crank it up again... it does this prolly 7/10 times I crank it.. any help appreciated
J_richmond09 is offline
post #2 of 8 Old 05-01-2019, 06:47 PM
Quoted: 337 Post(s)
Garage
Would be good to check the fuel supply pressure at the filter base. Could get all fancy and check for bubbles in the return line, using a loop of clear tubing.
Do you have a monitoring system? if so do the numbers look OK?
Torque Pro or Forscan -- there are others depending on your price.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 8 Old 05-02-2019, 03:37 AM
Quoted: 299 Post(s)
Bad lope and revving it for 10 seconds makes it go away?
I've heard it could be GPR, HPOP, fuel pressure etc etc.
Everything is correct on the scanner, IPR % and HPOP pressure.
I've dealt with it for a while and need to dig in to it. Let me know what you find.
White95f250 is offline
post #4 of 8 Old 05-02-2019, 04:30 AM Thread Starter
Quoted: 4 Post(s)
I’ll try some of those but it’s not 10 seconds I can just rev it for 1 second just get rpms up and it stops never have another issue until I crank it again
post #5 of 8 Old 05-02-2019, 11:32 AM Thread Starter
Quoted: 4 Post(s)
Ok update: I’ve been using the back tank for a while because I had to get a whole in the front one fixed... the lock ring on the sending unit was rusted and broke and caused the sending unit to be loose new lock ring and it fixed a little of the issue so I think that there maybe air in the lines
post #6 of 8 Old 05-24-2019, 05:55 PM Thread Starter
Quoted: 4 Post(s)
New update it’s still doing it lol
post #7 of 8 Old 05-25-2019, 07:20 AM
Quoted: 337 Post(s)
Garage
Originally Posted by J_richmond09 View Post
Ok update: Iíve been using the back tank for a while because I had to get a whole in the front one fixed... the lock ring on the sending unit was rusted and broke and caused the sending unit to be loose new lock ring and it fixed a little of the issue so I think that there maybe air in the lines
Check those fuel lines for damage, it only takes a little on the suction side to get air
Put a piece of clear hose on the return line to the tank at the fuel bowl with a loop to trap bubbles -- what do you see?
General note:
Hydro is offline
post #8 of 8 Old 05-28-2019, 09:00 AM
1Dieselman's Avatar
Quoted: 220 Post(s)
Feedback Score: 4 reviews
Most of the time when you have a lope at startup that goes away after revving it is a ipr or icp issue. You can start the engine with the icp unplugged to see if the problem goes away.
Hydro likes this.
1Dieselman is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
03 Gremlins - Intermittent No Crank/No Start bbressler 6.0 Motor problems 2 03-11-2018 04:31 PM
Truck won't start Cyclonus 99-03 7.3L Powerstroke Problems 7 07-03-2017 02:15 PM
08 Ford F-250 6.4L won't start when she is hot. Laceycruan Engine 911 0 06-28-2017 12:43 PM
First start / cold start problem Adam B 6.0L Problems Forum 0 12-05-2016 06:14 AM
