No start! - Page 2 - Ford Powerstroke Diesel Forum
 8Likes
post #11 of 31 Old 04-30-2019, 05:01 AM
Quoted: 2 Post(s)
When checking the pressure, saw that you should have a rag around the pressure gauge in case diesel sprays out. Also, should be around 30 psi when cranking I saw, 55 is running. I had to change the filter at least once a year when I had the manual fuel pump.
PalmettoJoe is offline
post #12 of 31 Old 05-02-2019, 05:14 AM
Quoted: 3 Post(s)
Check your HPOP pressure while cranking. Should climb quickly to at least 475-500 in order to crank. It's possible that your IPR sensor crapped out on you. When they go out you got nothing. My bet is that sensor crapped out. Facing the motor, It's located at the bottom right corner in the HPOP. Always good to keep a spare too.
bugtruck1* is offline
The Following 2 Users Say Thank You to bugtruck1* For This Useful Post:
chewd (05-09-2019)
post #13 of 31 Old 05-02-2019, 11:22 AM
Quoted: 6 Post(s)
Are you seeing all of the normal lights on the dash like wts and check engine? You could have blown the main ECM fuse if not. Also, is the tach bouncing when cranking?
Jack-Stand and Hydro like this.
bc_vickers is offline
post #14 of 31 Old 05-09-2019, 02:46 PM Thread Starter
chewd's Avatar
Quoted: 3 Post(s)
Okay, you don't happen to have a link for a preferred manufacturer do you?
chewd is offline
post #15 of 31 Old 05-09-2019, 02:49 PM Thread Starter
chewd's Avatar
Quoted: 3 Post(s)
Far as I am seeing everything looks normal. Cranking rpms look to be about 500ish...
chewd is offline
post #16 of 31 Old 05-09-2019, 02:55 PM Thread Starter
chewd's Avatar
Quoted: 3 Post(s)
I had seen that too on another thread somewhere. Did you swap to electric?
chewd is offline
post #17 of 31 Old 05-10-2019, 11:49 AM
Quoted: 3 Post(s)
Manufacturer of the HPOP, I would recommend the adrenaline HPOP, on the IPR and the IPC sensors, I recommend you go with a Ford or international part, all those generics are good for is working for a while then leave you on the road.
post #18 of 31 Old 05-15-2019, 04:09 AM Thread Starter
chewd's Avatar
Quoted: 3 Post(s)
So I check fuel pressure while cranking and it reads to be be 30psi. When turning over now, it’ll hit like it wants to start for a couple rotations but that’s it. I’m going to check the ipr sensor, I was informed that the those little aluminum backing nuts tend to loosen over time. Probably just gonna go ahead and replace it
chewd is offline
post #19 of 31 Old 06-14-2019, 07:21 AM Thread Starter
chewd's Avatar
Quoted: 3 Post(s)
Sorry for the delayed response everyone. I believe I found the problem after removing the fuel bowl I had planned to simply rebuild the IPR, but I found that the sensor casing has been cracked...
chewd is offline
post #20 of 31 Old 06-17-2019, 05:07 AM
Quoted: 3 Post(s)
Glad you found it. I was 95% sure it was the IPR with what you described. That cracked sensor will do exactly what you are describing along with acting like it wanted to fire up on and off when first trying to start. Be sure to give us an update on the status.
Similar Threads
Thread Thread Starter Forum Replies Last Post
03 Gremlins - Intermittent No Crank/No Start bbressler 6.0 Motor problems 2 03-11-2018 05:31 PM
Truck won't start Cyclonus 99-03 7.3L Powerstroke Problems 7 07-03-2017 03:15 PM
08 Ford F-250 6.4L won't start when she is hot. Laceycruan Engine 911 0 06-28-2017 01:43 PM
First start / cold start problem Adam B 6.0L Problems Forum 0 12-05-2016 07:14 AM
