steering issues - Page 2 - Ford Powerstroke Diesel Forum
 2Likes
post #11 of 16 Old 01-04-2019, 07:58 PM
Quoted: 466 Post(s)
Garage
Check the telescoping part of the steering shaft to see if it slides easily, the steering box shaft needs to move in and out slightly as you turn it, that is the valving working. Also sitting in the truck with engine off, turn the steering slightly and let go, it should spring back to center from both ways evenly.
If everything checks out, then the box is bad.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #12 of 16 Old 01-14-2019, 07:03 PM Thread Starter
Quoted: 2 Post(s)
I've concluded that the box is toast. The steering shaft,steering wheel, leaking oil. I've got a rebuilt one ordered. Will install as soon as the weather breaks. Thanks again all, I love this site and the help it gives!
garyeco is offline
post #13 of 16 Old 07-16-2019, 07:33 AM Thread Starter
Quoted: 2 Post(s)
Sorry about the delay getting back. Got the new steering box in and could't be any happier! That was my issue. Thanks to all.
Hydro likes this.
garyeco is offline
post #14 of 16 Old 07-16-2019, 08:44 AM
a known holder of grudges
SixStringMadness's Avatar
Quoted: 18 Post(s)
Garage
I put a RedHead on my '06 - very happy with it
I drive a Powerstroke, its not stock.
I put hard earned money into it
SixStringMadness is offline
post #15 of 16 Old 07-16-2019, 12:27 PM
Quoted: 466 Post(s)
Garage
A question about steering effort to turn the wheels: about how much effort to turn while sitting still? Can you "turn with the palm" or does it require more effort? Can you turn all the way to the steering lock?
@garyeco
@SixStringMadness
General note:
Hydro is offline
post #16 of 16 Old 07-16-2019, 12:41 PM
Quoted: 18 Post(s)
Garage
@garyeco
@SixStringMadness
Well, I have some impacting factors which make it "not-so-effortless"
I have 305 tires, that's a lot of rubber on the ground. Additionally I have a weakening/leaking power steering pump. My tires also rub a tad, so I don't often turn lock-to-lock.
However, I can turn the wheel sitting still without too much effort, but is something I traditionally avoid. I try to always be rolling, even if just a little so that the wear and tear on the steering components is less. The force to spin that rubber with all the weight resting on them isn't necessarily a gentle force, and is greatly reduced when the tires are rolling. In my mind, that means less wear on the moving components between the my hands and the asphalt.
It's a simple practice I've developed over the years, including others, that hopefully extends the life of the replaceables.....
