2004 6.0 HPOP O-rings and STC - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 2 Old 12-05-2019, 07:20 PM Thread Starter
Crank no start, ICP Pressure was
@ 300-400#
I've replaced the IPR, still a crank no start with low ICP
I ordered a kit to replace the STC and O rings in the HPOP.
When I got to the HPOP the cover and the HPOP is different than all of the ones I've seen on videos. The cover does not have the oblong whole on the top and the HPOP is different than the ones I've seen in the videos by Diesel Tech Ron and others.
I'm trying to find the correct o-rings and STC for the HPOP since two of the o-rings look damaged.
Here's the question... From looking at the pictures can anyone tell me the part numbers for the O-rings and STC that I need. The cover gasket in the kit that I have will work on my HPOP cover.
Anyone familiar with this?
Thanks
ID:	725777   Click image for larger version
ID:	725779   Click image for larger version
ID:	725781   Click image for larger version
Lloyd F-350 is offline
post #2 of 2 Old 12-09-2019, 06:25 PM
You have the early 04 engine here is the seal kit for whole icp system. https://www.amazon.com/gp/aw/d/B078H...b_b_asin_title
Crawfordp is offline
