Broken Fuel Fitting on Frame 2015 6.7 - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
 1Likes
post #1 of 16 Old 02-05-2019, 03:55 PM Thread Starter
Hey guys, I have a 2015 6.7 F250, I was attempting to change out the fuel lifter on the frame (looked like an easy job). I don't know if there is some trick to getting off the fuel lines, but of the 4, I only managed to get one off. Two are still connected, and the last one. Well, I snapped the plastic fitting on that one. The one with the blue clip, coming from the tank side. I still need to get the two with the yellow clips off, so if someone has a tip on that, I would appreciate it, but I'm really not sure what to do with the broken fitting. I saw there was something for the fitting near the injection pump, and I found this Dorman 800-050 which I apparently can't post a link to , but it's for the older models. Any help would be greatly appreciated. I tried to post a pic, but I don't have a post history, so I'm out of luck on that. I'm really hoping i'm not going to have to drop the tank and replace the entire line. Any help is greatly appreciated! Thank you.
Evilcactuar is offline
post #2 of 16 Old 02-05-2019, 05:13 PM
Your Local Windex Brewer
CrazyS0b's Avatar
Quoted: 603 Post(s)
@kaya @LoxDiesel One of these guys should be able to help you out.
2015 F350 SRW CCSB Lariat - Stock, for now
2008 F350 SRW CCSB FX4 - Airaid CAI, FloPro 5" straight pipe, Egr delete with BD intake elbow, SCT X4 with tunes from Tyrant Diesel, Monitored by CTS, Fox 2.0s. - SOLD
-Matthew
CrazyS0b is offline
post #3 of 16 Old 02-05-2019, 05:46 PM
Quoted: 477 Post(s)
Garage
I have needed to blow air into the connector to dislodge dirt so the clips can retract when pushing the button on the connector, also push the connector together a little as you squeeze the button to help release the clips.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #4 of 16 Old 02-05-2019, 05:52 PM Thread Starter
I have the clips up, but the line wont pull off.
post #5 of 16 Old 02-05-2019, 06:06 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 609 Post(s)
Feedback Score: 11 reviews
Why are you disconnecting the fuel lines for the frame fuel filter?
Clean the lines out, push line in, pop/squeeze/etc clip, pull line out.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #6 of 16 Old 02-05-2019, 06:07 PM
Quoted: 477 Post(s)
Garage
K, ...some you push others pull up, others pinch in two places, ...I am not familiar with the specific connector at the location you are referencing.
General note:
Hydro is offline
post #7 of 16 Old 02-05-2019, 06:18 PM Thread Starter
They pinch on the sides and pull up, but after I've popped the clips the lines still don't come loose.
I need to replace the fuel pump on the frame.
post #8 of 16 Old 02-05-2019, 06:20 PM
BBBRRRRRTTTTT
Quoted: 609 Post(s)
Push the line in, pull up all the way and pull the line out.
post #9 of 16 Old 02-05-2019, 08:01 PM
Quoted: 695 Post(s)
To release the line, pull the locking tab up. Then push the release tab (just in front of the locking tab) down. Push the line forward and then back while holding the release tab down.
As mentioned, blowing the dirt out and spraying with lubricant helps a lot.Always
For the broken fitting, does it connect to a metal section at the frame?
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark.
-Michelangelo
kaya is offline
post #10 of 16 Old 02-05-2019, 08:06 PM
Love all, Trust a Few...
LoxDiesel's Avatar
Location: If you go West and hit sugar cane come back a bit
Quoted: 1101 Post(s)
Thats the fuel pump, as well as a fuel filter. 1-1/4Ē socket, unscrew filter base and change filter.
Sent from my iPhone using Tapatalk
@loxdce
LoxDiesel is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
My 6.7 fuel pump install Merc82 6.0L Performance Parts Discussion 197 05-23-2019 07:56 AM
Water in fuel! pdsw60 6.7 Motor Problems (2011-2016) 69 08-13-2018 07:11 PM
Fuel line broken. Need part number Paul Armentrout 6.0L Problems Forum 0 05-31-2018 06:56 PM
7.3 PowerStroke Fuel Pressure P1280 (Ford 2002 Ford Excursion) KeithJohnson 99-03 7.3L Powerstroke Problems 4 10-27-2017 04:57 PM
99 F250 7.3, need fuel pump outlet fitting, where to find cursed99 99-03 7.3L General Discussion 2 08-16-2016 09:21 AM
