should i swap? - Page 2 - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #11 of 19 Old 01-16-2007, 04:15 PM Thread Starter
04mach1's Avatar
Send a message via MSN to 04mach1
whast the weak point in that motor?
how strong are the stock parts?
how much power cna i make from that longblock?
04mach1 is offline
post #12 of 19 Old 01-18-2007, 09:12 PM
How deep are your pockets. If it's built to the hilt you can make over 600 ponies. You sound mechanically inclined so I am sure you can figure out the wiring harness. By far the electronics would be the hard part. Stg1 injectors, intercooler, and tranny upgrades with good programming would make for a stout work truck and great DD. JMHO
Stroked95 is offline
post #13 of 19 Old 05-09-2007, 08:33 PM
i know the trans are the same , i think the flywheel and clutch is different
hotrod316 is offline
post #14 of 19 Old 05-09-2007, 09:23 PM
jngreen's Avatar
Send a message via AIM to jngreen
Im with Marty. Sounds like a great candidate for a cummins swap.
What tranny you got? Sounds like you have the zf5 speed..... They make adapters for those but they are pricey. By the time you build you build a powerstroke, you could have saved money by swappin in a 12 valve and throw in a 200 dollar set of marine injectors and remove the torque plate on the pump to make one heck of a smokin runner for cheap.....
jngreen is offline
post #15 of 19 Old 07-17-2007, 12:46 AM
I have messed with a lot of vehicles in my time, you are money and time ahead in the end selling what you don't want and buying what you do than trying to make something you don't like into something you want. Otherwise buy a wastegated turbo form Banks or ATS for $2500 and keep the IDI, they can be great motors.
ats85 is offline
post #16 of 19 Old 07-17-2007, 01:05 AM
rankroddin250's Avatar
corect me if im wrong here but i believe the 95's are obd1 instead of OBD2 and so that swap isnt going to give youi the advantage of a tuner or any thing plus you would probly be best off to get a compleate donor pickup so you know exactly where all the wires came from and where they go instead of looking at some mangled spider web in a card board box that the guy at the junk yard thinks will work for your truck quite personaly i would sell the idi truck you can get about 4 grand out of it and you can get a higher milage powerstroke for around 6-7 grand these days if you can do the swap and make it work for under 3 grand youd have it made but personaly i think that buying a power stroke would be the eiasier and more cost efficient way to go
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The People of a free country should not be scared of their government, the government should be scared of their people.
rankroddin250 is offline
post #17 of 19 Old 07-17-2007, 01:09 AM
oh i forgot to mention theoreticly the manifolds, up pipes, turbo, and down pipe from a powerstroke should be a bolt up to your motor you might have to do some fabricating but i saw a 6.9 with the fatory turbo set up off a PS with the injection pump turned up and it was pretty mean
post #18 of 19 Old 07-31-2007, 06:26 AM
7.3 PS
I saw that someone mentioned that 7.3 PS usually bring around 3 grand.
I have a '99 powerstroke from a van 175K miles no intercooler, harness comes with it. IDM and EEC. Radiator. flexplate. airbox. It appears to have a leaking rear main seal, and it sputters on hard acceleration (i think its a plugged fuel filter or lift pump) I bought this to put in my '89 F-250, but i don't have the time to figure out the electrical. I'm asking $1500 FOB Penn Yan, NY 14527.
let me know if you want pictures/ more details.
thanks,
Peter
pmartens07 is offline
post #19 of 19 Old 07-31-2007, 10:47 AM Thread Starter
04mach1's Avatar
could you send some pics and info to [email protected]
thanks
jer
04mach1 is offline
