turning up the fuel... - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 22 Old 02-04-2009, 04:46 PM Thread Starter
How do you turn up the fuel pump to get some black smoke? I dont know which screw to turn or whatever it is, any help is appreciated.
Thanks
ford_7.3 is offline
post #2 of 22 Old 02-04-2009, 04:52 PM
dalton1's Avatar
I dont think you can do that with a powerstroke.
03 F-250 Lariat Crew Cab SB 6.0L Auto 4x4
5" exhaust, AFE intake, Blue spring mod, EGR Delete, 58v FICM, Warren 175/75 injectors, Powermax Turbo,
ARP Head Studs, Coolant filter, Innovative tunes
Pine Tree Powerstroke Association Director
pm me for chapter info
dalton1 is offline
post #3 of 22 Old 02-04-2009, 04:54 PM
Joel's Avatar
Quoted: 10 Post(s)
Sorry man, thats a cummins thing. Look in the mod section for some quick, easy and above all cheap ways to make it go good. (And smoke a little)
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #4 of 22 Old 02-04-2009, 05:32 PM Thread Starter
bummer, thanks though
ford_7.3 is offline
post #5 of 22 Old 02-05-2009, 09:12 PM
FordGuy100's Avatar
What year truck? 87-94 Came with IDI's (94 was a year you could get 3 diff. engines. though.)
If its a 7.3 IDI, then its rather simple. First thing, is you need a pyro. Turning up the pump will melt your pistons if you dont know whats going on EGT-wise. Look at the IP, there will be a black triangular cover on the back passenger side of it. Under the throttle lever. Take two of the bolts out, and loosen the other so it can swing out of the way. Get yourself a GOOD 5-32" brand new allen wrench, you DO NOT want anything falling in that IP, really tight tolerances. Rotate the engine by hand until you see an allen screw in there. Turn it up a little bit. We measure it by "flatts", which are one side of the allen wrench. Start with 1 flat, then move yourself up if your EGT's arent to crazy.
But if its a powerstroke, then you cant do that.
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
post #6 of 22 Old 02-05-2009, 09:33 PM
back in the saddle
shu873's Avatar
He posted this in the IDI forums, so I'm betting that's what he's got. NOT a powerstroke.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #7 of 22 Old 02-09-2009, 11:36 AM
Which way do you turn the screw?
richiethrift is offline
post #8 of 22 Old 02-09-2009, 05:38 PM
FordGuy100's Avatar
You turn it clockwise, sorry I should have put that in there .
-Justin-
post #9 of 22 Old 02-09-2009, 07:58 PM Thread Starter
thanks alot, yepp its a 93 7.3l idi
ford_7.3 is offline
post #10 of 22 Old 02-09-2009, 08:32 PM
BennyLumpkin's Avatar
Send a message via AIM to BennyLumpkin
I ran my IDI pump as far as it would go and never....hauling 10000 pounds of hay in my enclosed trailer....i couldnt get the EGT's above 1200 with a stock downtube, and 4 inch to 5 inch stacks from there.....no intake either....just a stocker.....and it still didnt roal much coal....there are 2 diff set screws on IDI's....the one you talked about behind the triangular plate gives ya more power, the other is just for smoke lol.....have fun
The New Toy....06 F350SD CC Long Bed Dually, 6.0, Torqueshift, 4x4, 4.30 Limited Slip, Lariat, Edge Insight, SCT SF3 w/Innovative, S&B Cold Air, Zoodad Mod, 4 inch MBRP downpipe to 5 inch exhaust, Kenwood Flip up DVD w/nav and Sirius, Oil Cooler Rebuild, Sinister, CAT ELC, Extang Blackmax....more mods to come very soon
New Workhorse 2011 F450 V10 4x4 w/ Reading Classic II work body, 19.5's with SIMS, Boss 9'2" Poly VXT plow, XL badgeing with all XLT options but with a rubber floor.
BennyLumpkin is offline
