1989 7.3 very hard to start - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 4 Old 02-03-2009, 11:38 AM Thread Starter
I just replaced the golw plugs and controller. It just spins over and tries to start now and then. I don't know how many miles is on it. Once it starts it will start again no problem. it runs slightly rough but it seems to be firing on all cylinders.
Could the injectors need replacing? Any suggestions?
richiethrift is offline
post #2 of 4 Old 02-27-2009, 12:53 PM
DangerDave's Avatar
it sounds like it could be you injectors or your lift pump. i had a chevy with a 6.2l in it. it did the same thing it was the lift pump on mine i think it ran around $100.i was real ez to do
DangerDave is offline
post #3 of 4 Old 03-12-2009, 11:17 AM
95PDXLT's Avatar
sound slike a leak in the fuel system and it loses its prime while setting.
I had a 7.3 IDI that had a small tear in a oring on the return line at the pump and it would cause nasty hard starts. Crank and cranl untill builds prime
70 Dodge Charger R/T
97 ram 2500 cc 12v 4x4 5 speed turned up pump,4 inch straight pipe
89 GT Mustang 357W vic jr heads/intake, proform 750 Carb tremec 5 speed, 31 spline diff 4.10 rear, complete drag suspension, Mega bite sr lowers ect Sold
95PDXLT is offline
post #4 of 4 Old 03-15-2009, 05:36 PM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 26 Post(s)
i agree , need to run a fuel pressure test cold and see how long it takes to build up enough pressure to fire , if it runs ok after it starts then injection pump should be fine, just may be a leak down or even base pump pressure issue
ITS STOCK
SCUFFY828 is offline
