Glow Plug Clicking - Page 2 - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #11 of 15 Old 02-04-2009, 07:32 AM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 26 Post(s)
it is absolutly 100 % normal for these model relays to click, do not replace any parts , its doing what it is supposed to do
ITS STOCK
SCUFFY828 is offline
post #12 of 15 Old 02-05-2009, 03:37 PM
Brickrocket's Avatar
**edit**
Nevermind, I just recapped Scuffy's post before I noticed it was there
Brickrocket is offline
post #13 of 15 Old 02-05-2009, 05:21 PM Thread Starter
97-Stroker's Avatar
okay so the clicking is normal...now is it suppose to draw power like that? if you let it cycle till clicking stops the battery gauge clicks back everytime the relay clicks and then goes back to were it normally is before start up. it does this everytime it clicks. shouldnt it be drawing power the whole time there on not clicking on and off. I know my 97 pulls power the whole time the glow plugs are on cause i can watch the battery gauge click back to normal after i wait to start. ...hope this makes sense
Thanks guys
-Steve
SLS Diesel Performance
Cincinnati, Ohio
1997 F250 Supercab Long Bed PSD
Stage 1 injectors, Built trans, Tyrant tunes, Dana 60 swap, Fuel system, and Adrenaline HPOP
97-Stroker is offline
post #14 of 15 Old 02-05-2009, 09:15 PM
FordGuy100's Avatar
Thanks guys
-Steve
Glow plugs draw a TON of amps, so yes its normal for the gauge to do that. How long is the first draw? I mean if its 20* outside, and you turn the key to cycle the glow plugs and it automatically starts clicking at 1-3 second intervals, its not working properly. But if the initial one is like 7+ seconds long depending on the cold, and it does the short ones afterwards, then its normal. They are called afterglows, and it is to keep the fuel igniting in the cold combustion chamber on cold starts. Helps more and more as the temps get lower.
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
post #15 of 15 Old 02-06-2009, 03:22 AM Thread Starter
97-Stroker's Avatar
Well then thats my problem. Once i turn the key the wait to start light comes on for a second goes off and it starts clicking. does do a long one at first. The truck wont start in the cold. I would say 25 or lower. Its a plow truck so i need to get this thing fixed lol.
Thanks for the help guys
-Steve
Cincinnati, Ohio
