How To Modify The 7.3 IDI - Page 3 - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #21 of 28 Old 12-26-2008, 07:04 PM Thread Starter
RadarRider's Avatar
REMEMBER...
A 9 second ANYTHING will cost some major cash. There are 2-3 p-pumped powerstroke 7.3's out there. Rumors state that they are 15-1800hp.
While that's all well and good, they are no longer powerstrokes in my book.
If I had a 7.3 idi, I would turbo it and leave it at that. I would start sinking money into the truck itself and leave the engine alone. I've started to do the same thing to my truck..
10-4 on 9sec costing major cash! I don't think I'd go as far as trying to push 9sec out of it, but I would definitley look into a turbo. I've read an article on a p-pumped rig & it was absolutely astounding. It started off as a HUEI PowerStroke & got the ol' p-pump with a cutom intake fabricated by the owner. I'm sure whoever reads diesel mags knows exactly what I'm talking about(Stroked Out)! Anyway, like I said; I'm going with your advice & just stopping @ the turbo with the IDI. I really want to modify Heavy as much as I possibly can before I dig into the Tank. Plus, if Heavy ever breaks down from my skilled mechanical ability(), I'm really going to need something to tow 'er back to HQ. What are some secrets I need to know about the IDI. I just did a serp belt today & boy did that suck! The IDIs I used to work on had standard belt tensioners that worked with either a 1/2 breaker bar fitting or socket. This one has a piston that I had to move with a pry bar & man, that was a pain in the arse! The more I inspect this truck, the less of an idiot I think the guy that sold it to me is. He just didn't seem to know anything about diesels or anything automotive. But I did find the oil was clean & up to level, the left rear shackle & hanger had been recently replaced, new fuel filter, & all the lights work.
"HEAVY" 2001 F-250 XLT 4x4 EC SB:
TW 6pos chip, S&B CAI, Monster 4" exhaust w/ Power Elbow, Big Head WGA, Technicooler, ITP boost fooler, Gen 1 Wicked Wheel, Six-Gun Tuner, Optima Yellow Tops, AutoMeter(Boost, Trans, EGT), CCV mod, MTS TC, MTS valve body, Trans Tech performance rebuild kit, TransGo shift kit, Hornblasters 242 Shocker Train Horns.
RadarRider is offline
post #22 of 28 Old 12-26-2008, 08:50 PM
rtmerck46's Avatar
Quoted: 2 Post(s)
Garage
Send a message via AIM to rtmerck46
another thing to check is the oil cooler those are known for having the o rings go bad on them i jus did mine over the summer isnt too too hard jus a PITA getting it in and out
1999 F250 CC SB 4x4 Zf6 swap Kentucky clutch ceramic DD, php hydra, 3" all suspension lift on 37s, CNC Fab 4 line feed, Dieselsite 66mm wicked wheel.
1989 F350 CC LB 4X4 N/A 7.3l IDI zf5 swapped and rebuilt engine. sold[/B]
rtmerck46 is offline
post #23 of 28 Old 12-30-2008, 01:47 PM
powerstrokes only's Avatar
My '94 IDI with the factory turbo is pretty amazing to me. I have over 300,000 miles and it is a pulling sucker!!!! I turned it up, replaced exaust from the turbo back, got a Hypermax intake, a K&N air filter, and I built a Hydrogen unit for it. I pull a 40' flatbed with it grossing over 30,000lbs and it pulls great! It pulls within 5-10mph of my stock 6.4, but it gets 10-12 where the 6.4 gets 6-8mpg. These engines have great low-end torque!! I have had a blast working with my two old 7.3's and love driving them, I am sure you will enjoy yours too! A turbo will make a HUGE difference, do this first, I have been impressed with the Banks turbos for these trucks too! Good luck.
Fletcher
'90 F250 Supercab IDI 7.3
Banks Sidewinder Turbo
4'' straight pipe
116,000 miles
'94 F250 single cab IDI Factory Turbo 7.3
3'' banks down pipe
Banks pyrometer
3 1/2'' straight pipe
K&N Air filter
Hypermax air intake
Hydrogen Generator
Pump turned up
Timing advanced
315,000 miles!
'89 F250 4x4 supercab 7.3 IDI
4'' exhaust
pump turned way up!!!
297,000 miles
powerstrokes only is offline
post #24 of 28 Old 12-30-2008, 05:23 PM Thread Starter
RadarRider's Avatar
I still can't get over the fact Banks makes a turbo kit for it. I do love that truck. Besides it needing 4 new shocks, it's getting excellent MPGs & it shifts so much smoother than my '01!
post #25 of 28 Old 12-30-2008, 05:30 PM
Broncoguy's Avatar
IDI
Banks isn't a real popular name with the Powerstroke crowd, but I have the Banks sidewinder on my 92 and it is the best money I have spent on that truck hands down. The power difference is unbelievable. The only other thing I would suggest is a intercooler. Just get a stock one out of a superduty someone has upgraded and do the plumbing yourself. It made a big difference on my truck.
1999.5 F350
4" Straight Pipe / Gauges (Pyro, Boost)
Wicked Wheel / Wg delete / Boost fooler
Tymar intake / Zoodad Mod / NChornet CCV mod
Hpx Crossover / Fuel CCK / ITP prepump tank mod
FPR Shim w/ underhood gauge
AIH Delete / Non Ebpv pedestal w/ valve delete
TW 6 position chip (will never own another canned toon)
3.73's / 6 speed manual 4x4
Still messin with it
Broncoguy is offline
post #26 of 28 Old 12-30-2008, 05:47 PM
rtmerck46's Avatar
Quoted: 2 Post(s)
Garage
My uncles 88 has over 500,000 miles on it and he has owned it since day onew and he still hauls with it and he prefers it over his 06 6.0l
post #27 of 28 Old 12-30-2008, 07:21 PM
FordGuy100's Avatar
Same thing with my truck. It was originally my grandfathers truck which he bought new back in 85'. It has lower milage than that though, its just coming up on 130,000 miles . He has a 97 Dodge 2500 cummins, and used the Ford more than that truck, and has told me the Ford was without a doubt the best/most like vehicle he has ever owned.
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
post #28 of 28 Old 12-30-2008, 08:07 PM
Cynic
Dirk's Avatar
Banks + IDI = awesome reliable power
Banks + powerstroke = F'n
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
Voluntary Banishment: Knowing when to leave.
Total Diesel Performance\Unlimited Diesel Performance\Diesel Innovations\BTS\Terminator Engineering\Swamp's Diesel Performance\Black Widow Diesel\Calvert Racing
Dirk is offline
