Injectors.... - Page 2 - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #11 of 12 Old 07-12-2008, 02:08 PM Thread Starter
rtmerck46's Avatar
Quoted: 2 Post(s)
Garage
Send a message via AIM to rtmerck46
thanx again fordguy100 u've been really helpful
1999 F250 CC SB 4x4 Zf6 swap Kentucky clutch ceramic DD, php hydra, 3" all suspension lift on 37s, CNC Fab 4 line feed, Dieselsite 66mm wicked wheel.
1989 F350 CC LB 4X4 N/A 7.3l IDI zf5 swapped and rebuilt engine. sold[/B]
rtmerck46 is offline
post #12 of 12 Old 08-09-2008, 12:39 AM
It'd be interesting to check out those injectors. Do you know what method they used to increase the size of them?
As for the injection pump with new injectors the new injectors may have a higher pop off pressure but that pressure is significantly lower than the actual injection pressure. So I doubt that they are keeping a "worn out" pump from pumping properly. Typically what happens with these pumps when they go bad is the advance piston bore gets worn out and lets to much transferpump pressure by and therefor won't advance the timeing properly. An easy way to test to see if that is what's happening is to push the bottom of the verticle lever on the side of the pump in and if the idle doesn't change it needs an overhaul. Unfortunately this is something you need to tear the whole pump apart to do so you have to just do a comoplete rebuild.
Also the cheap $350 rebuilds are just that. Cheap. They only replace a couple worn out parts and that's it. A good quality rebuild with all new wear parts will cost more than that just in parts.
'96 F-250 Extended Cab, long box 4X4, 4" lift, 35" tires
Injectors, Intercooler install kit-GTS Motorsports
Crower rods, H11 Head studs, Cam, Chip Diesel Innovations
Gen II HPOP, chip-Swamp's Diesel
Chip Live Tuned from Power Hungry
Current Chip Tuned by me!
Transmission BTS
custom turbo kit with HX40.
[email protected] in 1/4 mi!
466hp #2 only
805hp NČO
Yeah I can keep up!
gtspowerstroke is offline
