I think ATS sells the upgrade for the downpipe/exhaust housing on the intercooler. But I think its like $800. You might want to take it to a muffler shop, tell them to cut the downpipe off at the flange, and then weld a mandrel bent 3" pipe into it. That way you have the stock mounting, but then it goes into a nice round 3" pipe instead of that cobra head downpipe.
I have a 6.0 intercooler sitting at home, though its a custom thing to put it in. Thats why I havent started. Hypermax sells a intercooler kit, but its like $1500.
Turning up the pump wont decrease fuel milage, only your right foot will. If you cruise, you will get the same milage, but at WOT you will be injecting more fuel, therefore your fuel economy will go down some.
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
