No start - Page 3 - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #21 of 22 Old 09-16-2010, 05:46 AM
I believe it bogs down with the starting fluid because diesel helps lubricate and starting fluid cuts the diesel out and w/o more coming in it just is metal on metal. I am having a simular issue as I am not getting any fuel into the engine atm and I tried SF and got the "bogging down" you speak of. So no more SF until I figure out why no fuel
Waterlogged is offline
post #22 of 22 Old 09-23-2010, 08:00 AM
FordGuy100's Avatar
The itense amount of power that happense because the pump advances the timing a chit ton to get some more rpms so it can suck some fuel from the tanks.
I would guess like a 10-15*bump in timing.
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
