Swap 7.3 idi for gas? - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 3 Old 08-02-2018, 07:56 AM Thread Starter
AJamesR's Avatar
Garage
Luckly my powerstroke in my van has been flawless, I love it! But now I come to you because the 7.3L idi in my fire deprtment's F350 medic unit seems to have died. Our department is very very small with almost no budget to speak of, so we need to find the cheapest way to get the truck running again. A new diesel is way too much and used ones seem to be hard to find or have way too many miles on them.
So my question is: what would it take to put in an older gas engine? Are there any that will bolt to the transmission? It's a heavy rig, but never tows and never goes out of town real far, so a diesel isn't really needed and old ford gas engines seem to be a dime a dozen. Plus there are a lot of people on the department that can work on gas should it have issues down the road.
Thanks
Jumbo White Knight
1995 Powerstroke Econoline 350 retired Ambulance
AJamesR is offline
post #2 of 3 Old 11-25-2018, 03:46 PM
greenskeeper's Avatar
Quoted: 299 Post(s)
Thanks
probably something simple.
12v to the fuel solenoid?
fuel at the injectors while cranking ?
Gunga galunga...gunga -- gunga galunga.
97 F-250 CC 4x4 7.3L PSD E4OD 203K all original
99 F-250 CC 4x4 7.3L PSD ZF6 253K all original
greenskeeper is offline
post #3 of 3 Old 12-08-2018, 08:38 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 7 Post(s)
Feedback Score: 4 reviews
have you talked to any shops about actually fixing the current engine? with swappin a gas engine into it, your going to have to really clean out the fuel system, and possibly replace the fuel pump/ and pick up in the tank. the lines are full of diesel, maybe a shop is willing to cut you deal being as its an emergency service vehicle, but just swapping a gas engine is is fairly simple, especially if your going to a carb, but then your going to be tinkering with a carb forever, and unless the engine is a new reman, your going to be SOL when repair time comes because you're going to have at best a 60 day warranty from date of purchase.
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
