91 f250 7.3 nonturbo fuel leak plz help - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
 7Likes
  • 1 Post By uberdude
  • 2 Post By Rattlesnake18
  • 2 Post By SparkyF250
  • 2 Post By h0trod
post #1 of 7 Old 07-15-2017, 03:52 PM Thread Starter
91 f250 7.3 nonturbo fuel leak its leaking up on the intake from a round junction deal where all the fuel lines run into this has 8 lines i think and it seems like the very bottom line is leaking i took the line off not seeing any rub holes . i dont know what you call this circle junction port thing . also the lines screws into a fitting that looks to be screwed into this port thing . does the fitting come out to or is it made onto this round thing ? hope this make sense to someone lol sorry new to diesels . this is my only wheels and cant drive it because of this leak .
uberdude is offline
post #2 of 7 Old 07-15-2017, 04:40 PM
AMERICA!
Rattlesnake18's Avatar
Quoted: 1739 Post(s)
Feedback Score: 6 reviews
I have no clue, but maybe these guys can help ya... @SparkyF250 @jrcowboy
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #3 of 7 Old 07-15-2017, 05:13 PM Thread Starter
yea i hate to sound dumb but no idea what to call it . yea i am sure someone on here knows its right above the breather on top of the intake round 8 fuel lines screwed into it
SparkyF250 likes this.
uberdude is offline
post #4 of 7 Old 07-15-2017, 05:18 PM
AMERICA!
I personally only know of a couple members here that have IDIs, two of them are the ones I mentioned. There is another guy, but I haven't seen him around in a bit... @h0trod
h0trod and SparkyF250 like this.
post #5 of 7 Old 07-15-2017, 08:00 PM
SparkyF250's Avatar
Quoted: 3372 Post(s)
Garage
You're talking about the thing in the thumbnail pic below right? That's your fuel injection pump. Is one of the lines leaking or the pump itself? If it's the pump leaking I don't think it's serviceable in the truck. There are a few places that rebuild them fairly reasonably, these guys can rebuild it to the stock calibration or give you a boost. Injection Pumps I'm sure you can find other shops as well. Here's another one, fuel injection injection pump injection pump rebuilding injection pump repair, Conestoga Diesel Injection Fuel Injection and Turbocharger Rebuilding. The Moose Pump people! Willow Street, PA Home
BTW you'll need to reference a service manual to swap that pump as there is timing involved. No reason you can't do it if you follow the instructions. And any time you're working on the fuel systems you must keep everything clean. Cap lines etc. I'm not sure if @[email protected] carries IDI pumps or not, he'll see the mention and let you know.
Operation of the 6.9 and 7.3 International-Navistar IDI fuel system | The Hyperlogos
(I didn't watch all this video, it's just to give you an idea)
Give me a shout if you have any more questions, I'll do my best to help.
Name:	idi pump.jpeg
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is offline
post #6 of 7 Old 07-15-2017, 08:04 PM
SparkyF250's Avatar
Garage
Yeah I was gonna mention @h0trod too, one is cause he knows these things inside out, and two I want to see his latest Frankentruck The guy is a first class fabricator.
Rattlesnake18 and h0trod like this.
Sparky
post #7 of 7 Old 07-15-2017, 09:11 PM
Machinist & Fabricator
h0trod's Avatar
Quoted: 58 Post(s)
Garage
awww shucks guys,
yea I have been workin up a storm on actual work these days, got a new contract for the DOD.
the MANchero has been on pause, and ive been doing side projects to fund a fuel system.
funny I decided to check in on the day someone needed IDI help lol
as far as the round thingy that has lines coming out of it.
the pump itself isn't really serviceable., and if its leaking, it would leak near the front/middle if the injection pump (IP)
if its leaking in the rear of it, I would suspect that your fuel feed line has a broken olive.
its the hard line that goes from the filter to the center of the round thingy with 9 lines connected.
the olive of which I speak is a rubber grommet that seals the line, it is one of fords most lamest flaws.
I believe these olives are supplied in a injector return line kit.
I always delete this line and install a AN style line.
you can find them at conestogadiesel.com
Rattlesnake18 and SparkyF250 like this.
2001 F350 CCC SB DRW
1998 E350 7.3 clubwagoon
94 F25Bronco
87 F350 6door 94 7.3 IDIT moose motivated ZF5
63 MANchero 97 7.3 on a 89 F350 frame
1945M-37 IDI/ZF5 2WD
1941 1/2 ton pick up in the planning stages
many gassers, irrelevant here
h0trod is offline
