7.3 IDI turbo - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
LinkBack Thread Tools
Old 11-02-2009, 09:26 AM Thread Starter
7.3 IDI turbo
I am looking to buy a 7.3 IDI turbo from 2001 for my boat, but i have no exprerience of them.
I got pictures of engine from the seller, can you see if it a marine 7.3 IDI or just "normal" truck engine?
This is the details from the original bill
Date: Nov 7, 2001
Total price: $8717.32
Serial Number: 233189
Sorry guys if my english is not the best, live in Finland
Thanks
kafelsan is offline
Old 11-02-2009, 09:27 AM Thread Starter
One more picture
kafelsan is offline
Old 11-02-2009, 06:12 PM
Quoted: 4 Post(s)
Wow I never knew that they put these in boats, now I have a new junkyard to search. From teh looks of it the turbo kit is def. not the same as a truck. The rest is greek to me. I have a Econoline engine in my truck, I would think a boat and truck and boat engines would be basically the same, just bolt on stuff...
1997 F-250 HD XLT CCSB 4x4, 7.3L PSD, ZF5, Dana 60
08+ diff cover, 33x12.50R20's on Moto Metal 962's
3" DP to 5" straight pipe, pyro & boost guage, HPx Line,
Edge Evo, CX Racing intercooler, 6.0L fan, 1.0 Housing,
SD pump, bowl delete E fuel, 4.10, EBPV delete and ped
LEDs and HIDs, Ranger shift knob, RiffRaff Billet wheel
Black, Tan interior.
38' Gooseneck Enclosed Car Hauler.
Mototime2000 is offline
Old 11-02-2009, 07:32 PM
FordGuy100's Avatar
They have a "maranized" kit for these IDI's.
I would be worried about cavitation, which lets oil and water mix in the engine. It is caused by the wrong coolant being used, and as I think these trucks pull water from whatever body of water the boat is in, I dont know....
So just go look at it, make sure it runs good, no blue or white smoke, ect.
And your english was fine my friend
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
Old 11-02-2009, 07:35 PM
FordGuy100's Avatar
But it is a regular old pickup 7.3 IDI...the only difference is it has different exhaust manifolds, a turbo setup, and the cooling system. Everything else should be the same.
-Justin-
Old 11-03-2009, 06:15 AM Thread Starter
Thanks for you time and help guys!
The seller claims the engine Propshaft 260HP, must be about Crankshaft HP290-300 does it sound reasonable?
Engine Serial Number: 233189
Can you chip it to get more hp?
Thanks again for all help i get from you guys!
Fredrik
kafelsan is offline
Old 11-03-2009, 09:31 AM
FordGuy100's Avatar
I've heard they had them turned up way high. I honestly dont know what they do to achieve that though.
The motor is in-direct injected, and is all mechanical, so if you want more power you have to do it yourself. I dont know if you can turn it up anymore as it already is pretty high.
What are you going to do with it?
-Justin-
Old 11-03-2009, 09:50 AM Thread Starter
Put it in my boat
I have gas V8 Mercruiser 454 330hp, but i am thinking about to change to diesel (cheaper to drive).
kafelsan is offline
Old 11-12-2009, 05:45 AM
Were can I find out more about these "marinized" kits. I had thought that the compression ratios in marine diesels were different then the ons in trucks, making it not worth it to put a truck engine in a boat. I am thinking of repowering my 28ft hatteras but cant afford new diesels but a pair of 7.3 IDIs would be awsome. The simplicity of these engines would be great.
LItrailers is offline
Old 11-12-2009, 10:08 AM
FordGuy100's Avatar
I have only seen these kits for sale...not much info at them.
The compression might be a little lower, that might be true. The higher compression wont hurt in a boat, it'll still turn those props.
I would love this swap too...if you do it get plenty of pics!
-Justin-
