Slow speed "lunge"? - Ford Powerstroke Diesel Forum
6.7 Tranny Problems (2011-2016) 6.7 Tranny Problems
post #1 of 22 Old 10-05-2015, 05:08 PM Thread Starter
BryanDowdy's Avatar
Quoted: 3 Post(s)
Slow speed "lunge"?
I recently did a EGR/DPF delete on my '13 F350. Now when I'm in a parking lot or anytime driving slowly (1-4 mph), the truck seems to "lunge" at around 5 mph. It's like a spike in power/speed. I've talked to the company who supplied the tune and it seems it's not the tune causing the issue. Truck never acted the way before the delete. Any ideas or suggestions?
BryanDowdy is offline
post #2 of 22 Old 10-17-2015, 09:45 PM
Quoted: 8 Post(s)
Not sure if this helps you at all or not.
Running a 15 (also deleted). I can tell you that the acceleration is pretty sensitive at low speeds. There is no real sweet spot on the gas pedal for cruising 5-15 mph. I just feather it now.
I couldnt tell you how it was before the delete, wasnt original long enough.
ropegun2k is offline
post #3 of 22 Old 10-17-2015, 09:49 PM
Your Local Windex Brewer
CrazyS0b's Avatar
Quoted: 599 Post(s)
When you tune you generally increase the throttle response. This can cause any little movement like small bumps or you moving to cause a noticeable surge. As long as the trans isn't slipping or slamming you don't need to worry.
2015 F350 SRW CCSB Lariat - Stock, for now
2008 F350 SRW CCSB FX4 - Airaid CAI, FloPro 5" straight pipe, Egr delete with BD intake elbow, SCT X4 with tunes from Tyrant Diesel, Monitored by CTS, Fox 2.0s. - SOLD
-Matthew
CrazyS0b is offline
post #4 of 22 Old 10-19-2015, 06:43 AM Thread Starter
BryanDowdy's Avatar
Quoted: 3 Post(s)
Mine only does the lunging under 5 mph. and it's not like a constant surge or anything. Just single lunge.
I'm not concerned about damage being cause, I don't feel like it's hard on the tranny. I've heard of guys complaining of the same problem that are not deleted/tuned. I've just never heard what they have done to fix the problem.
post #5 of 22 Old 10-30-2015, 01:44 AM
T diesel's Avatar
Quoted: 21 Post(s)
Is it up-shifting?
T diesel is offline
post #6 of 22 Old 10-30-2015, 10:59 AM Thread Starter
BryanDowdy's Avatar
Quoted: 3 Post(s)
No its not up-shifting, stays in 1st. It does it under all these conditions under 5mph:
Forward/Reverse 2wd & 4wd
Forward/Reverse 4wd Lo
Traction control off
Manual selected 1st gear
On a incline or decline
Tow/Haul On & Off
I believe it has to be something in the throttle or something that the throttle uses for feedback. I acts the same under all the conditions above and I've been towing 12-15k in the mountains the past month without tranny issues.
post #7 of 22 Old 10-30-2015, 11:01 AM Thread Starter
BryanDowdy's Avatar
Quoted: 3 Post(s)
I even had a tune wrote with no power increases or changes to the tranny, only disabling the emissions. No change in the lunge.
post #8 of 22 Old 11-04-2015, 07:05 PM
Sterling6.7's Avatar
Quoted: 29 Post(s)
Mine has a similar trait to what you are describing. I went from the H&S engine/stock trans tune to a GH engine and trans tune. Much better low speed drivability and shifting. I would suggest looking into a different tune.
Sterling6.7 is offline
post #9 of 22 Old 11-05-2015, 11:58 AM
DIGMAR's Avatar
Quoted: 28 Post(s)
SAME!! with the canned H&S tunes I had the same surge in low speed/low gear. driving in parking lots was unbearable. Switch to the GearHeads tunes and fixed it.
DIGMAR is offline
post #10 of 22 Old 11-19-2015, 03:59 PM Thread Starter
BryanDowdy's Avatar
Quoted: 3 Post(s)
Just got a GH tune and it's still doing! Did you tell them anything in particular to correct the issue?
