Slow speed "lunge"? - Page 2 - Ford Powerstroke Diesel Forum
6.7 Tranny Problems (2011-2016) 6.7 Tranny Problems
post #11 of 22 Old 11-20-2015, 03:18 AM
Sterling6.7's Avatar
Quoted: 29 Post(s)
Might be the difference between an SCT and H&S tuner. Might also be the trans relearn that you need to work through. I noticed mine more when the truck is cold.
Sterling6.7 is offline
post #12 of 22 Old 11-20-2015, 06:10 AM
DIGMAR's Avatar
Quoted: 28 Post(s)
As far as having the tune adjusted, best way to do it is if you have a CTS or some type of gauges that can monitor throttle position. When I had mine tweaked, they wanted to know what was happening, what shifts it was occurring at, and what throttle percentage I was seeing it at. Give them a call and they can work with you on it. They were quick to send updated tunes and fine tuned it a few time until it was perfect.
DIGMAR is offline
post #13 of 22 Old 01-05-2019, 07:51 AM
I know this is an old thread, figured it was worth seeing if you solved this issue?
My truck does the exact same thing, and though I don't think it's damaging anything, it's really obnoxious, It's actually difficult to drive in parking lots and at slow speeds, almost embarrassing sometimes because people think you're gassing it towards them or something.
carlt2000 is offline
post #14 of 22 Old 01-15-2019, 04:48 AM Thread Starter
BryanDowdy's Avatar
Quoted: 3 Post(s)
Unfortunately, I never found out what causes this and have just learned to live with it.
BryanDowdy is offline
post #15 of 22 Old 01-15-2019, 05:52 AM
Heavy_GD's Avatar
Quoted: 3109 Post(s)
Garage
Feedback Score: 4 reviews
the only option you have is to change the tune and see if it s follows... the trans will eventually learn your style but its not made to creep at 1mph in a parking lot, so to Bryans point just drive around it.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #16 of 22 Old 01-15-2019, 06:16 AM
jman37's Avatar
Quoted: 335 Post(s)
Garage
It's been said over and over, it's the power increase. Like said, there is no "sweet" spot in the gas pedal. At low speeds, for example, in parking lot if I'm in 1st, and light on the throttle, the RPM's raise and it will shift into 2nd creating a "lunging" motion, then all is fine. It sounds like your truck just doesn't shift into 2nd, and stays in 1st. All trucks are different.
jman37 is offline
post #17 of 22 Old 01-15-2019, 06:40 AM
It's not the trans tune, It's throttle related. I'll start off in 1st and try to just slowly drive through a parking lot and at about 900 rpm it'll lurch up to 1,200 and rocket me forward until i get off the throttle, and doesnt shift in to 2nd. The original tune they gave me it would upshift in to 2nd during this and i'd launch even more. And it's not the power increase, because I have the stock power tune with just the delete mods.
post #18 of 22 Old 03-25-2019, 05:31 PM
I'm in the same boat. Hate it, to the point I regret buying the truck. I tried cleaning the intake, tracing any leaks by pressurizing the turbo inlet, different fuel additives, different tunes (same company package of 5 tunes) all are the same. Didn't do this before delete. Its like something lets loose at 1100 rpm and from there to 1500 rpm you would have thought I punched it! At 1500 rpm it smooths out perfectly. Thought I found a small intake leak that helped but didn't work.
cdorsey50stang is offline
post #19 of 22 Old 04-12-2019, 11:23 AM
Mine does this too! I'm waiting on a revision right now.
GVFD903 is offline
post #20 of 22 Old 04-13-2019, 07:00 AM
Let us know if you figure anything out. Super annoying! Makes me want to go back to a cummins.
