Hood Cracked from Fatigue - Page 4 - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2017-2019) 6.7 Problems Forum
 63Likes
post #31 of 42 Old 06-13-2019, 06:25 AM
Quoted: 50 Post(s)
Missing information
I see a number of comments from people but has anyone asked if there is a wind deflector attached to the hood? Or have the hood stop heights too low? I've never seen this on a ford but on another vehicle, the hood was warping. The stops were too low forcing the owner to slam the hood to close it. I could go on, but I think you get the ideal.
HeavyAssault likes this.
iHenry is offline
post #32 of 42 Old 06-13-2019, 07:22 AM
Brrrrrrr......cccccold
Quoted: 384 Post(s)
This definitely does not appear to be stress cracking, spider cracking or not. The location is wrong for that.
I have a degree in Mechanical Engineering with materials specialty. I've done plenty of structural engineering (nuclear field) and plenty of FEA. I'm not even going to pretend I'm an expert by just looking at the pic of that hood. But there's more to it than the pic....
Just sayin'.....
@HeavyAssault Well Said!
HeavyAssault and iHenry like this.
Zach
07 F250 KR FX4 CCSB, Dark Copper Metallic/AZ Beige, Rotella T6
6000K HIDs, Zoodad, Fog mod/High Idle, Tinted, Rancho 9000s, Banks CAI,
Blue Spring, NUC/Amsoil Bypass Oil Filter
Z36 slotted/drilled rotors, Carbon Ceramic brake pads,
Warren 175/stock, Atlas 40, Fleetrite ELC, ScangaugeII
168,084 miles....
Air Force Veteran......Go Blue!
Support Our Troops - Remember Our Veterans!
zsargent is offline
post #33 of 42 Old 06-13-2019, 07:33 AM
Hate stupid people
CloverLeafFarm's Avatar
Quoted: 302 Post(s)
looks like a fat chick fell off a flatbed wrecker and onto the hood.
lucky the axle didn't snap
iHenry likes this.
Illiana Strokers DICtator
EFI Live tuned 6.7
CloverLeafFarm is online now
post #34 of 42 Old 06-13-2019, 05:10 PM
Quoted: 50 Post(s)
I would have expected a bigger dent.
iHenry is offline
post #35 of 42 Old 06-14-2019, 12:42 PM
Hi, I have over 50 yrs in the aluminum industry. This does not look like fatigue. This looks like a mfg problem or the hood was damaged and repaired. A met evaluation will tell you what the problem is but be prepared to shell out some money. I would...
1. Check the trucks history for accidents and repairs.
2. Just buy a new hood section, paint it and diy repair.
BamaBoy100! is offline
post #36 of 42 Old 06-14-2019, 03:12 PM
ZMANN's Avatar
Quoted: 3857 Post(s)
your experience speaks volumes
thanks for taking the guesswork out of this
6.0 flush pdf
ZMANN is offline
post #37 of 42 Old 06-15-2019, 04:46 AM
Hate stupid people
Quoted: 302 Post(s)
saw it at schieds
ZMANN likes this.
EFI Live tuned 6.7
post #38 of 42 Old 06-15-2019, 08:38 AM
ZMANN's Avatar
that is believable even if it is a cover story LOL
6.0 flush pdf
ZMANN is offline
post #39 of 42 Old 06-15-2019, 09:38 AM
Jjorgis5569's Avatar
Quoted: 40 Post(s)
Originally Posted by Sollly View Post
It is definitely from driving down the road. I have a degree in Aerospace Engineering with a lot of knowledge on Fatigue cracking. The spider pattern is a indicator. As I said the outside of the hood is perfect. I have an identical XLT right next to it and the hood profiles are exact on outside.
You can hold the center of the hood and flex each side up and down just as the hoods do in high winds and and it flexes and pops right at the cracks. It appears the inner layer and outer layer are also de-laminated. I assume they were held together with adhesive at one point.
I’ll have to disagree on fatigue cracking. Looks more like freq vibration. Impossible to tell if it’s low, mid, or high without mounting an accelerometer. If you have an aerospace degree, it wouldn’t be hard to convert the hz to rpms, then determine which component spins at said rpm. Or—————-
Check your motor mounts, trans mount, and stop drill the cracks to prevent them from spreading. Any vibration from power plant will have to run through the mounts. My parents still have a 94 Cummins dually they bought new. Same scenario with that. Fuel tank straps kept cracking, bed, fenders, and hood. Basically everything except the cab.
iHenry likes this.
Jjorgis5569 is offline
post #40 of 42 Old 06-15-2019, 11:16 AM
SparkyF250's Avatar
Quoted: 3157 Post(s)
Garage
Yeah but everything cracking on a Ram is normal. Good engine in a junk truck.
iHenry likes this.
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is online now
