Backup Camera Intermittent Failure - Page 2 - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
 3Likes
post #11 of 19 Old 07-25-2018, 06:33 AM
CBarker's Avatar
2015 just started doing the same thing, but it is getting worse. Zero warranty left. Anybody have a definite fix? Got my first error message the other day.
CBarker is offline
post #12 of 19 Old 07-25-2018, 07:05 AM
Heavy_GD's Avatar
Quoted: 3168 Post(s)
Garage
Feedback Score: 4 reviews
All these people and no one has taken the time to source out the connections mentioned above.
@djmaguire
I would take this harness, unplug it and securely plug it back... then tie it up and away from the parking brake
djmaguire and The Evil Twin like this.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
The Following 2 Users Say Thank You to Heavy_GD For This Useful Post:
josephd2212 (09-30-2019)
post #13 of 19 Old 07-25-2018, 07:31 AM
djmaguire's Avatar
Quoted: 1588 Post(s)
Garage
Sheeeeet... I thought that these new fancy-schmancy trucks were completely wireless!?
The pic that @Heavy_GD posted appears to be the real deal, fellas. Clean, grease, and secure that connector.
Heavy_GD likes this.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #14 of 19 Old 07-25-2018, 07:49 AM
Heavy_GD's Avatar
Garage
GD
Heavy_GD is offline
post #15 of 19 Old 12-22-2018, 09:28 PM
new7.3strokin's Avatar
Thanks for taking the time to take a picture of the proper connector. I appreciate it
new7.3strokin is offline
post #16 of 19 Old 06-09-2019, 09:19 PM
Hunter6146!!'s Avatar
Quoted: 16 Post(s)
Originally Posted by SpyderXLT View Post
BUMP! Would anyone happen to have a wiring diagram or a pinout for the above mentioned connectors? Mine's doing the same thing (2014 F350 DRW). I'm considering relocating the C210 connector OFF of the parking brake mount to avoid any further issues, but I've first got to identify and correct the deficiency.
GUYS THE CONNECTOR UNDER THE BUMPER right before it comes through the tailgate is loose youíre gonna have to get a couple of zip strips and zipper tight. But before you do that I would get some electrical cleaner and clean it real good
Hunter6146!! is offline
post #17 of 19 Old 09-12-2019, 08:10 AM
nycpsd's Avatar
Had this problem as well. What it ended up being is the harness that the camera connects to within the tailgate to under the bumper. The harness contains a bare wire wrapped in shielding between splices at either end of the harness(To cut interference from the reverse aid system). There was no corrosion in any of the terminals but after disassembling the harness found a spot where the corrosion was breaching through the shielding (no wire chafing found on the protective plastic tubing). Also a fair warning is when you remove the rear Ford emblem it will break, ford has this listed as a one time use part and must be replaced. There are then 2 long bolts holding in the rest of the housing and 2 Christmas trees holding the harness into the bottom of the tailgate. Both connectors on the harness are single locking tab release as well.
Harness part# FC3Z-14A412-A
Emblem link: https://www.tascaparts.com/oem-parts...wtdjgtZGllc2Vs
Emblem part# CL3Z-9942528-AA
nycpsd is offline
post #18 of 19 Old 12-21-2019, 01:28 PM
Quoted: 11 Post(s)
Just fixed this issue on my 2014. Replaced the harness that plugs into the camera that goes into the tailgate. Cost $30 on amazon. I tried blowing out the connectors on both ends of the old harness with no luck. As soon as i replaced the cable, crystal clear.
Harness Part# FC3Z-14A412-A
travsav is offline
post #19 of 19 Old 01-16-2020, 04:03 PM
On my 2015 it was where the harness plugs into the camera by the ford oval. What I did was removed the tailgate plastic on the inside so I could access the camera back and plug. I then had the key in the on position not started and opened my back window so I could see the camera. I started wiggling connections and found it to be the back of the camera plug. Put some dielectric grease in and good as new.
Zsteinmetz is offline
