6.7 Injector and Glow Plug Module Issue - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 6 Old 01-07-2020, 11:08 PM Thread Starter
I recently fully deleted my truck (2011 XL Extended cab). Had a knock for a long while, and it turned out it was an injector. Decided to change out the injector when I did the egr delete (inj #2.) Well I changed it and the knock went away but I doesn’t sound like it’s idling right. Making a loud tap-like sound from the exhaust and throwing white smoke. Not a lot, but enough that it’s visible, my pops says it smells like diesel, so I think it’s running rich if anything. I want to take it to the dealer so they can program the fuel rate on said injector. But I read somewhere that once I deleted and tuned the truck that this wouldn’t be necessary since the programming is designed to work with the DPF system. Is this true? And one other thing, I’m getting a code coming up about having lost communication with the glow plug module since I did the EGR delete (did that maybe a week after I deleted the exhaust), what could be the problem here? There’s one sensor I can’t find where to connect to, it’s right under the air filter box and has a green tip, might that be the issue for the glow plugs?
Thank you in advance for the replies!
post #2 of 6 Old 01-08-2020, 08:05 PM
Quoted: 38 Post(s)
Yes that plug goes to the module. It plugs in under the battery tray.
Early 11s had valve issues where they would crack. This creates a popping noise out the exhaust and will result in a loss of compression causing while smoke. It could also have been the source of the balance fault code on cylinder 2. Have someone with an IDS run a relative compression test and a power balance test.
Was it a motorcraft injector?
06 King Ranch
Fass 200, Custom fuel lines, 225/100s, Thumper stage 2 hpop, WPE stage 3 intake, Mishimoto radiator, Flex a lite fans, BPD water pump, MPD oil cooler relocate kit, Intercooler pipes, Compounds built by me, etc etc etc
05 Eddie Bauer
Resealed entire motor @ 170k miles, new lifters, 6.4 push rods, studs, rebuilt the turbo, IPR egr delete, new injectors, new heads, new ficm board, coolant filter, intercooler tubes, regulated return, bunch of other new parts. Factory exhaust, cat gutted(wife's rig). Livewire with gearhead tunes. Should go a while reliably for her!
03 LB7 duramax the "daily/tow pig"
Lbz cp3, s475/stock twin kit, built trans, steel driveshft, amsoil bypass, secondary oil cooler built by me, fass, traction bars, trans cooler upgrade, dual alts, straight center link + tie rod sleeves, efi live, transfer flow/tool box tank, 5er hitch, other small upgrades.. and most importantly, STOCK HEADBOLTS! Just rolled 200k miles, twins installed @ 165k, daily driven on a "550 tune" tows 18k on a "475" tune.
Nickjames525 is offline
post #3 of 6 Old 01-18-2020, 07:26 PM Thread Starter
Thanks for the advice, I just replied because I have to take the valve cover off and hadn’t received any notifications from my email that there was a reply (sorry!!) And yeah, it was a motorcraft. Had it programmed at the dealer and about 3-4 days in, I had an issue with the injector. Ended up getting loose along with the fuel line. Had to get towed. I tightened everything thing to spec so I don’t think that should have happened, but oh well. I took it out today and turns out there was two copper washers in there (maybe a third?) so I think the fuel wasn’t burning right due to the bigger gap. I say maybe a third because it looks like there’s another one where the injector tip goes. It’s in a, ‘C’, shape (Broken) and appears to be stuck. But anyway, I dropped what could either be one, or two, washers into the valve cover and now I’m going to be taking it apart tomorrow. I’m also going to change out those glow plugs. This has turned into a huge pain.
post #4 of 6 Old 01-18-2020, 07:29 PM Thread Starter
Also, when I had it programmed the smoking went away, so I don’t think it was a valve issue, but I appreciate the heads up.
post #5 of 6 Old 01-19-2020, 06:37 PM
Quoted: 38 Post(s)
22 ft lbs + an additional 90* is spec. The bolt has to stretch to ensure its tight.
06 King Ranch
05 Eddie Bauer
post #6 of 6 Old 01-21-2020, 11:42 PM Thread Starter
Yes sir, much appreciated!
