Leak at rear backing plates - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
 1Likes
  • 1 Post By Hydro
post #1 of 7 Old 12-08-2019, 06:20 AM Thread Starter
Quoted: 8 Post(s)
Anyone know what the line in the photo is for? It is leaking on both sides but this is the worse one (Driver's side). It goes into the backing plate opposite of the brake calipers.
Any info is much appreciated.
Sorry for the rotated pic. Don't know why it rotates when uploaded.
Name:	f250 leak at backing plate.jpg
Phil S is offline
post #2 of 7 Old 12-08-2019, 07:37 AM
7.3lf550's Avatar
Quoted: 91 Post(s)
I beleive that is the ABS wire. It is probably the axle seals leaking. How many miles?
03 7.3l 550, FRx, 6637 mod, 4 inch turbo back, ccv delete, aih delete, HPx, Riffraffs OCR, Turbo-pyro-boost-coolant EV2 gauges, Bullydog GT tuner.
03 X 6.0 175/30 warren sticks, Livewire TS w/ warren tunes, Blue spring mod, atlas 40 ficm, 270amp dc power alt
Originally Posted by Heavy_GD View Post
goats lives matter.
7.3lf550 is offline
post #3 of 7 Old 12-08-2019, 10:37 AM
Work Truck Fanatic's Avatar
Quoted: 29 Post(s)
I 2nd that. Axle seal is leaking
2017 Ford F250 XL 4x4 SRW, White
Work Truck Fanatic is offline
post #4 of 7 Old 12-08-2019, 10:41 AM Thread Starter
Quoted: 8 Post(s)
78,000 miles
Phil S is offline
post #5 of 7 Old 12-08-2019, 11:55 AM
ZMANN's Avatar
Quoted: 4014 Post(s)
i would think your ABS sensor O-ring is a probable cause
6.0 flush pdf
ZMANN is online now
post #6 of 7 Old 12-08-2019, 12:06 PM
Quoted: 476 Post(s)
Garage
Check the axle vent to see if it is open or the hose damaged
wasps will plug the hose sometimes -- a small engine fuel filter will keep them out
Excess pressure in the axle housing will cause the seals to leak -- relieving the pressure may fix the seal leak
ZMANN likes this.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #7 of 7 Old 12-08-2019, 03:18 PM Thread Starter
Quoted: 8 Post(s)
Thanks for the responses.
Just checked the vent and it's clear....so, back to the dealer.
Phil S is offline
