2011 6.7 question - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
 1Likes
  • 1 Post By kaya
post #1 of 8 Old 06-17-2019, 11:36 AM Thread Starter
2011 6.7 question
Trying to help out a stranger that was stranded, he has a 2011 6.7 that he changed out both Fuel filters , says he did the proper cycling of the key to get the fuel back, drove it about a mile and it died and wont start back up. I had my code reader on me and he is getting P20BA and P2074. I have researched the codes but it just seems strange that this happened right after changing the filters, any help or advise would be greatly appreciated.
Thanks
Chad
Crawl101 is offline
post #2 of 8 Old 06-17-2019, 11:44 AM
jman37's Avatar
Quoted: 400 Post(s)
Garage
2074 is for a MAF sensor. Probably dirt/grime build up, or a false reading. 20ba is for DEF heater. He's probably had that one for a while I'm guessing but the truck hasn't gone into reduced power mode. I had the same problem, but I could drive and drive and drive. I would reset it and it would come back 100 miles later. The 2074 code could not really be the MAF itself. I replaced mine, and it ended up being an EGT sensor downstream causing the misreading.
'11 F-250 RCLB FX4 6.7 - Deleted, SCT GTX - Tyrant tuned, Duratrac's on Moto Metal 962's - Sold
'17 Grand Cherokee SRT - Stock
'97 SVT Cobra - Few things
'88 Mustang LX - Built 306ci, built AOD, 4.10's - Sold
'06 F-350 ECSB Lariat FX4 6.0 - Studded, deleted etc..-Sold
'07 F-250 XLT ECSB 4x4 6.0 - Studded, deleted etc..-Totaled
jman37 is offline
post #3 of 8 Old 06-17-2019, 12:13 PM Thread Starter
jman37-- would the 2074 keep it from starting? and also have caused it to just die?
Thanks in advance
Chad
Crawl101 is offline
post #4 of 8 Old 06-17-2019, 12:39 PM
jman37's Avatar
Quoted: 400 Post(s)
Garage
It shouldn't. Mine never died with that code, always started for me.
jman37 is offline
post #5 of 8 Old 06-17-2019, 01:06 PM Thread Starter
Thanks for the info, ill try cleaning it this afternoon and ill let you know what happens
Crawl101 is offline
post #6 of 8 Old 06-17-2019, 01:14 PM
Quoted: 695 Post(s)
Can you view fuel rail pressure with your device?
I've seen these trucks stall out after being run and having air still in the system, following filter replacement.
What i like to do in that case is disconnect the return line off the secondary (engine mounted) fuel filter and cycle the key on. Then reconnect the line. It'll make a good bit of mess but it should fire up afterward.
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark.
-Michelangelo
kaya is offline
post #7 of 8 Old 06-17-2019, 01:16 PM
Quoted: 695 Post(s)
Oh and there was a recent tsb Come out for that p2074 dtc. pcm reprogram.
Not sure if 2011 were affected though.
If not, there are a myriad of possible culprits.
However, from my experiences with the code, it was usually either the maf or map sensor causing it
jman37 likes this.
-Michelangelo
kaya is offline
post #8 of 8 Old 06-17-2019, 01:27 PM Thread Starter
Thank you very much for the input, I will check what you said as well.. Much appreciated
Chad
Crawl101 is offline
