Starting issues - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 5 Old 06-03-2019, 05:09 PM Thread Starter
Starting issues
When turning the key the starter stutters several times then turns over, anyone else have this issue?
SMOKE004 is offline
post #2 of 5 Old 06-03-2019, 05:12 PM
Quoted: 105 Post(s)
What year is your truck and how old are the batteries?
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #3 of 5 Old 06-03-2019, 06:34 PM Thread Starter
Sorry I should have put that, it’s a 2015, batteries are original
SMOKE004 is offline
post #4 of 5 Old 06-04-2019, 02:25 AM
Quoted: 105 Post(s)
Your batteries might be the problem since they are the originals. I just had to replace mine in my 2015 last month. I would take the batteries and have them load tested. Make sure you isolate them so you are load testing each battery and not both at once.
Larry
post #5 of 5 Old 06-04-2019, 06:32 AM
Don't load test them, just replace them. My '14 Lariat wouldn't start by key but would start by remote so I replaced the batteries and all is well.
Sent from my SM-N960U using Tapatalk
schlepprock is offline
