Hub bearing/ABS sensor - Page 2 - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #11 of 17 Old 03-10-2019, 02:59 PM Thread Starter
Quoted: 2 Post(s)
Ok, so I finally got it off and replaced. I bought 2 set of snap ring pliers that wouldn't fit inside, ended up buying a set of snap ring pliers from Harbor Freight to get that off. Then I couldn't get it to budge at all, even after all 4 nuts were removed. Someone on Facebook shared a video with me that shows how to use a socket extension and the power steering to get it to pop loose, worked like a champ. Then it took me a lot of swearing an patience to get the snap ring back on. I appreciate the help you guys gave.
2015 F250 Mayhem Riot 18x9 Falken Wildpeak AT3W, Diamond Eye 5" exhaust, S&B intake
nc1yocum is offline
post #12 of 17 Old 03-10-2019, 08:01 PM
NC1yocum, can you please share the video, I’m also on Facebook Stephen Shook
Chessiecam08* is offline
post #13 of 17 Old 03-11-2019, 04:58 PM Thread Starter
Quoted: 2 Post(s)
Originally Posted by Chessiecam08* View Post
NC1yocum, can you please share the video, Im also on Facebook Stephen Shook
Hopefully you're the one I sent the message to. Check your other messages since we aren't friends.
nc1yocum is offline
post #14 of 17 Old 05-26-2019, 12:01 PM
Quoted: 5 Post(s)
Id love the video as well. I just replaced one side and it was a bear!
Jasonburrwc84 is offline
post #15 of 17 Old 05-26-2019, 12:04 PM
Quoted: 5 Post(s)
I replaced one side and reused the speed sensor. However, now Im getting random abs/advance track warnings. Has anyone else experienced this? Could it be from not replacing the speed sensor? Could it be from having one wheel assemble factory and other MOG? Any thoughts?
post #16 of 17 Old 05-26-2019, 12:25 PM
Quoted: 105 Post(s)
odds are it is the speed sensor. Hubs shouldn't matter on whose name is on the box.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #17 of 17 Old 06-18-2019, 08:03 PM
Quoted: 5 Post(s)
Ended up being the speed sensor. Replaced it and all was fine. Thanks again.
Similar Threads
Thread Thread Starter Forum Replies Last Post
ICP Sensor O-ring (Not seal) part number bahadur General 6.0L Discussion 0 06-17-2018 07:27 PM
Coolant Temperature Sensor not getting power cdroadwarrior 99-03 7.3L Powerstroke Problems 11 11-25-2017 07:48 AM
Overhead Console-DIFFERENT ISSUE 6.0 Hauler 6.0L Electronics Discussion 1 04-18-2017 01:19 PM
Trouble with PSD dtc # 1316 bubba 1541 99-03 7.3L Powerstroke Problems 23 09-09-2009 07:23 AM
Trouble Codes Marty 99-03 7.3 Repair Help 0 11-19-2006 07:35 PM
