2015 F250 Coolant Leak - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 1 Old 02-20-2019, 11:52 AM Thread Starter
Quoted: 2 Post(s)
I noticed an orange puddle on the garage floor. After looking underneath I found what I thought to be the leak. It was the lower radiator hose that goes to the front of the motor. I removed the hose and replaced the o-ring. Job complete. About 1 week later I see another puddle on the floor. Unfortunately I was unable to crawl under this time to track down the leak. I take it to the shop and I find out the radiator is leaking on the driver side. I have that fixed. Leak's fixed! Not so fast. The truck is parked at work and there is a shimmer of wet underneath. More anti freeze. The truck goes back in the shop. The system was pressure tested and was found to be the first o-ring that I replaced. That was switched out and good to go...so I thought. There is still a leak and I'm not taking it back to a shop unless I have to.
What I have since noticed is that the main overflow tank on the back of the bay on the driver side is low. I topped it off with about 1/2 gallon this morning, didn't drive it since topping it and it is leaking onto the floor. Any thoughts on where to look to try and track this down?
Jason_M is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
6.0 Coolant leak back of block passenger side cruukedeye 6.0L Problems Forum 7 12-02-2018 08:45 AM
Coolant smell at temp - no leak? TheMagicSpoolBus 6.0 Motor problems 3 08-11-2018 07:13 AM
2002 f250 crew cab Oil Leak DarthF250 99-03 7.3 Motor Problems 2 06-18-2018 09:38 AM
2012 F250 6.7 Diesel Coolant Leak crzytxn General 6.7 Discussion (2011-2016) 7 07-13-2017 06:01 AM
Coolant leak Trashcan04 6.0L Problems Forum 3 11-12-2016 08:16 AM
