Haze at idle (Weight loss) - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 5 Old 02-18-2019, 08:51 AM Thread Starter
Quoted: 7 Post(s)
So, I've noticed at idle on several occasions a haze (white/blueish/gray..?) coming from tailpipe when truck is warm. Not full operating temp warm, but say around 155*. It's super faint, like if you stand on one side of truck and look hard it's visible, if you look from another direction you can't see it.
As far as maintenance goes, I can't pinpoint an area of concern. Air filter is new, fuel filters up to date, oil changed on time, etc. OA from Blackstone has come back good last two times...I'm running GDP tuning, currently on a 135hp tune, but noticed it also on OEM tune. I don't see smoke any other time...Barely see smoke @ WOT on current 135hp tune.
My exhaust is 5" Flo-Pro with Donaldson resonator and Donaldson 41" muffler. You can see straight through resonator and muffler--pic attached.
CCV is vented to atmosphere.
Any thoughts?
ID:	714891   Click image for larger version
BMLS is offline
post #2 of 5 Old 02-18-2019, 09:26 AM
J98
J98's Avatar
Quoted: 6 Post(s)
Garage
Common symptom after tuning. I wouldn't worry much, you've already gone to more work then most do.
J98 is offline
post #3 of 5 Old 02-18-2019, 09:30 AM Thread Starter
Quoted: 7 Post(s)
Thanks and good to know!
BMLS is offline
post #4 of 5 Old 02-20-2019, 04:04 AM
11kingranch's Avatar
Quoted: 37 Post(s)
Garage
I am having this same issue. Did the full weight loss around a year ago and didnít have this issue until a couple months ago. The haze will make your eyes water if you come close to it.
Been wondering if I have a bad injector?? Has 176k miles
Sent from my iPhone using Tapatalk
11kingranch is offline
post #5 of 5 Old 02-20-2019, 05:13 AM Thread Starter
Quoted: 7 Post(s)
Have you cleaned your MAF sensor? I'm curious if it could be related to a dirty sensor.
Also, check out video attached. This is @ cold start, after sitting 16hrs. approx. 30* ambient air temp. Notice idle variation.
BMLS is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
6.0 Loss of power dies rough idle 6.0 Medic 6.0L Problems Forum 5 02-03-2019 08:01 PM
U0422 after weight loss Treatcg 6.7 Performance Parts Discussion (2011-2016) 2 12-09-2018 08:41 AM
Weight loss remorse? MagnoliaTom 6.7 Performance Parts Discussion (2011-2016) 34 01-20-2018 03:42 AM
Off idle loss of power mikew04f250 General 6.0L Discussion 4 09-06-2017 05:51 AM
RV Towing aggriffin2 Camping/RV's 23 07-23-2017 07:58 AM
