Rubbing with stock tires? - Page 2 - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
 1Likes
post #11 of 26 Old 02-28-2019, 05:04 PM
-Falcon-'s Avatar
Quoted: 397 Post(s)
Garage
40k? Your truck is 4 years old. Isn't the warranty 5years 60k miles on the drivetrain? I would think the hub/bearings is part of the drivetrain.
2007 F250 Crew Cab Lariat 4x4. Lots of upgrades, but not enough. It's tall, too tall. Yes, I'm obviously compensating for something.
UPGRADES:
EGR Delete, RedHead Steering Gear, Blue Spring Upgrade, ARP Studs, (Let's not mention this manufacturers name) Coolant Filter, (Let's not mention this manufacturers name) Blue Intercooler Pipe and Elbow Upgrade, Cold Air Intake, One-Up Offroad Traction Bars, XD Wheels and Nitto Ridge Grappler 37" Tires, LED Lights all around, 2013 Tailgate, 2008+ Power Mirrors, Pro-Comp XXX Dual Front Coilover Suspension, Custom Bedliner Sprayed Rocker Panels and Fender Flares, Amerihood Tpe E-Style Ram Air/Heat Extraction Hood, CompuStar Alarm with Remote Windows, Remote Start, and much more!
More upgrades to come, including Singer Alternator, and other engine upgrades.
NEW Custom Bumpers with Tire Carrier! Dual Winches!
-Falcon- is offline
post #12 of 26 Old 02-28-2019, 05:27 PM Thread Starter
The Evil Twin's Avatar
Quoted: 159 Post(s)
Yessir. Since it is 4wd , I would assume the front bearings are drivetrain but don't know fo sho. I meant disappointed just because it is not a lot of miles. Most I see go well above 100k.
I would love to take the truck in, but I know how hard it can be to diagnose a sound. Especially when it is seemingly random. My fear is that it would be a waste of time.
The Evil Twin is offline
post #13 of 26 Old 02-28-2019, 05:36 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 600 Post(s)
Feedback Score: 11 reviews
Might as well take it in for funsies. Tech might say f it and put a set of hubs on it.
Where in nova are you? My dads in Stafford county...
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #14 of 26 Old 02-28-2019, 06:04 PM Thread Starter
Quoted: 159 Post(s)
I'm not too far from Stafford in Prince William County. Just off the Hellhole called I66. Lol.
post #15 of 26 Old 03-01-2019, 05:25 AM
G8orFord's Avatar
Quoted: 2526 Post(s)
Garage
I had a noise in my '04 that I thought was the unit bearing, but with basic inspections with it on jackstands I could never say for sure it was the problem. I finally pulled the caliper to where I could really get down to just the bearing with no other interference. Even then, at first I wasn't sure, but when I turn it slowly and used a stethoscope, I could hear the flat rollers. When I swapped the bearing, the noise on the road was gone. The bearing itself felt great, no slop, and it spun very well too. At speed though, it made a noise.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #16 of 26 Old 03-02-2019, 03:35 AM Thread Starter
Quoted: 159 Post(s)
Looks like I may finally have a dry day! Well, dryer anyway. I still don't think its a bearing because it is only intermittent, when turning and going uphill at an angle. But.... I have been wrong before. Just ask my ex.
post #17 of 26 Old 03-02-2019, 07:27 AM
Quoted: 46 Post(s)
Ive had wheel bearing failure on stock 08 at 40K before. No noise on straight driving. Only noticed at odd angles and turns. Jack it up and check. My money is on bearing.
Grish76 is offline
post #18 of 26 Old 03-02-2019, 07:47 PM
I had what sounds like a similar issue. My driver front tire would rub on the wheel well liner only when turning left, with some articulation. I could see where the wheel well liner was kinda warped inward a little, towards the tire. I just cut out the are that looked warped, no more noise.
AzRocket is offline
post #19 of 26 Old 03-03-2019, 04:18 AM Thread Starter
Quoted: 159 Post(s)
Well, no luck so far. I jacked up one side of the truck at a time to flex the front a bit and nothing looked close. I wiggled each front wheel and found no noticeable play. I drove up a loading ramp one wheel at a time. Ugh.
I am almost inclined to think that there is something moving behind the dash, or under the hood. I'm going to try to root around the engine bay today. I did make sure the batteries are snug in their homes.
post #20 of 26 Old 03-09-2019, 04:49 AM
Mylan1988's Avatar
Quoted: 4 Post(s)
My truck makes the same sound with leveling kit and stocks, pretty sure it’s not the tires. I think it has something to do with the ABS in my opinion. Was on a small road going about 10mph and the road turned sharp and went downhill in the turn an it made the sound and then one of the brakes on the front felt like it locked and then unlocked. But it has only done that once. But I can turn left out of work everyday and it makes the sound. I know my tires don’t rub.
Mylan1988 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Build Thread: TowBoss F350 6.0L PSD. colo_dually General 6.0L Discussion 73 10-05-2019 10:35 AM
295/70R20 tires on stock wheel 03274398 Wheels, Tires, and Brakes 1 10-15-2018 10:40 AM
What are the cheapest tires that are the most common that I can put on my truck Bramstroker 94-98 7.3L General Powerstroke Discussion 28 09-28-2018 07:39 AM
Don't miss Pro Comp Summer Offer on Rims and Tires at CARiD! CARiD CARiD.com 0 07-10-2018 05:29 AM
