A/c clutch wont stay engaged - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 4 Old 06-08-2018, 08:14 AM Thread Starter
So I've had issues with my ac, last year had to replace the pump. Everything worked good until now. It wants to stay cold whenever it wants and gets cold randomly. I took it to a ac shop they couldn't figure it out, we dumped freon and charged it to spec. No luck. All the relays and fuses work. Then replaced pressure switch. We direct wired and what do you know ac was blowing cold and non stop. I'm pulling my hair out why wont the clutch stay engaged.. please help
Erickp13 is offline
post #2 of 4 Old 06-08-2018, 09:46 AM
Quoted: 133 Post(s)
Probably electrical if jumpering the switch kept it running. A/c clutch gap too wide can also cause irratic operation so best to check and rule this out as well.
Ross
2006 f-250 CCSB king ranch diesel 4x4. Stock w/ air bags, rancho 9000s, and coolant filter.
Rossterman is offline
post #3 of 4 Old 06-08-2018, 09:51 AM Thread Starter
Appreciate the advice I will be checking the gap once I get home and post what I find wrong with it.
Erickp13 is offline
post #4 of 4 Old 07-21-2019, 04:47 AM
Coreyciv95's Avatar
Quoted: 8 Post(s)
Ever find a solution to this. Is the clutch gap serviceable like the older generation super duty?
Coreyciv95 is offline
