Oil leak, low Power Steering fluid, Brakes pop, Vacuum pump? - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 8 Old 01-30-2017, 07:08 AM Thread Starter
Quoted: 4 Post(s)
Hello,
Over the past few months I've noticed that I have to completely refill my Power Steering reservoir about once a week or once every two weeks. I start loose power steering and get a loud whine front the front, and my brakes pop as if anti-lock brakes are kicking in all the time. Sometimes a stiff pedal too. I've also been getting less then the usual fuel mileage which I've assumed is from a dirty air filter. I've had some issues with fuel pumps in the past I don't know if that could relate at all. Anyone have an idea as to what's going on?
yupitsnuge is offline
post #2 of 8 Old 01-30-2017, 07:17 AM Thread Starter
Quoted: 4 Post(s)
according to the coffee table book, the job of the vacuum pump is -
"The vacuum pump is located on the
upper portion of the front cover and is
driven by the high pressure fuel pump.
Vacuum is used for the EGR cooler
bypass system and the wastegate
control system."
I've deleted the DPF & EGR system.
I'm wondering if because my fuel filters we're completely covered in gel (so much so the truck died) that it put a ton of strain on the high pressure fuel pump and that blew out the vacuum pump gasket? or at least further loosened the vacuum pump bolts? is that even possible?
post #3 of 8 Old 02-23-2017, 08:27 AM Thread Starter
Quoted: 4 Post(s)
aaannnyyyooonnneeeee???
post #4 of 8 Old 02-23-2017, 08:30 AM Thread Starter
Quoted: 4 Post(s)
Also noticed this weekend that I'm leaking a lot of brake fluid from the MC
post #5 of 8 Old 02-23-2017, 09:29 AM
Heavy_GD's Avatar
Quoted: 3152 Post(s)
Garage
Feedback Score: 4 reviews
@kaya , throw us some knowledge.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #6 of 8 Old 02-23-2017, 11:43 AM Thread Starter
Quoted: 4 Post(s)
I should have said... "Also noticed this weekend that I'm leaking a lot of brake fluid from the MC AREA" Not sure it's the MC exactly...
Does anyone have a Brake and Power Steering diagram?
post #7 of 8 Old 02-23-2017, 08:07 PM
Quoted: 695 Post(s)
Is the vacuum pump gasket leaking? Super common. Bolts tend to loosen over time.
What year and model is the truck? Some later years used vacuum assist brakes.
But if you're leaking fluid near the MC, and your PS fluid is dropping, is probably leaking PS fluid from one of the 3 lines at the hydro boost, just rear of the MC
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark.
-Michelangelo
kaya is offline
post #8 of 8 Old 02-24-2017, 03:07 AM Thread Starter
Quoted: 4 Post(s)
Kaya,
Thanks for the reply. The truck is a 2012 F350.
I'm not sure what's leaking just yet. I noticed it only after continually filling up the PS. i will check and report back.
