'12 F250 P2291 ,NO START,HELP! - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 37 Old 12-11-2016, 06:08 PM Thread Starter
Quoted: 4 Post(s)
I have a crank and no start condition with P2291.The truck has 177K miles (highway)
The fuel rail pressure sensor shows first 350psi at KOEO then decided to replace it with a NEW sensor and now
shows 0 psi at KOEO. While cranking still shows 0 psi .I put back the old sensor and again shows 350 psi at KOEO and cranking . Looking at the Commanded Fuel Pressure it changes from 4,300psi to 6,000psi.
Any ideas what is happening ?
ioang26 is offline
post #2 of 37 Old 12-11-2016, 06:57 PM
Quoted: 681 Post(s)
Does the fpl pid change from low to not low with the key on?
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark.
-Michelangelo
kaya is offline
post #3 of 37 Old 12-12-2016, 08:56 PM Thread Starter
Quoted: 4 Post(s)
Yes, the FPL PID changes from LOW to NOT LOW when commanded from the scan tool .
Also,I did a few more tests today :
1.Took a fuel sample of the high pressure fuel rail and I could see on the bottom
of the black spray cap some very,very fine(almost dust ) metal particles
2.Replaced the fuel pressure regulator (FPR) - the old one had a little rust on it
3. While cranking the fuel rail pressure was going from 0 to 115psi and when the cranking stopped
it went back to 0 psi.
4. Pinched the injectors return line - made no difference in the pressure either with KOEO or cranking
5. Unplugged the FPS and the PCM defaulted to 31,200 psi - again no start
The Lift pump is NEW and the engine mounted filter has been replaced.
Is the HPFP gone already or there is some massive leak which prevents even to build up any minimum pressure with KOEO?
Any additional tests I should try ?
ioang26 is offline
post #4 of 37 Old 12-12-2016, 09:45 PM
Quoted: 681 Post(s)
Is p2291 the only code present?
Can you post a clear pic of your fuel sample please?
-Michelangelo
kaya is offline
post #5 of 37 Old 12-13-2016, 06:49 AM Thread Starter
Quoted: 4 Post(s)
Here are the samples. Yes, there are two codes: P2291 and P2539 (Low pressure Fuel system Sensor Circuit) The second one showed up immediately after replacing the High pressure sensor .I don't know why.
ID:	583529   Click image for larger version
ID:	583537   Click image for larger version
ID:	583545   Click image for larger version
ID:	583553   Click image for larger version
ioang26 is offline
post #6 of 37 Old 12-13-2016, 06:54 AM Thread Starter
Quoted: 4 Post(s)
A little better pic
ioang26 is offline
post #7 of 37 Old 12-17-2016, 07:04 AM
Quoted: 2 Post(s)
Doesn't look good for your HPFP...
honemch is offline
post #8 of 37 Old 12-17-2016, 07:16 AM
Quoted: 2 Post(s)
Would be awesome if this was your problem....
honemch is offline
post #9 of 37 Old 12-17-2016, 10:29 AM
Quoted: 681 Post(s)
Originally Posted by ioang26 View Post
A little better pic
That doesn't look like it would cause 0 pressure.
Check supply pressure with a gauge. Should be roughly 80 psi.
If that's good, check for aerated fuel using a clear line
-Michelangelo
kaya is offline
post #10 of 37 Old 12-17-2016, 10:36 AM Thread Starter
Quoted: 4 Post(s)
Where should I install the clear line to check for aerated fuel? At the fuel return line at the back of the rail? If that shows positive what would that point to?
ioang26 is offline
