Interior light problem - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion (2011-2016) 6.7 Powerstroke Interior Discussion
post #1 of 5 Old 12-19-2014, 08:39 PM Thread Starter
brdgraf's Avatar
My interior or cargo lamps will not come on when door is open or when I try to turn them on with holding dimmer switch up. The guage display does show when door is ajar so makes me think a fuse or relay possibly but I have had no luck figuring out which one? Anybody else heard of this or have any ideas?
2012 F-250 6.7L Lariat CC White platinum and pale adobe two tone
AFE Pro dry intake
Recon smoked cab running lights w/ amber LED's
Recon smoked mirror side lenses w/ amber LED's
brdgraf is offline
post #2 of 5 Old 12-30-2014, 04:43 PM
Coffaro's Avatar
My back dome light will not come on when the doors open but the front map lights do...
Coffaro is offline
post #3 of 5 Old 12-31-2014, 07:44 AM
ASarsano's Avatar
Quoted: 31 Post(s)
brdgraf - Deff sounds like a fuse. the the switchs styill operate which is why the dash shows when there open. Do all your Cig lighters, Or power supplies work? normally there on the same fuse as the dome light.
Coffaro - Sounds like youre bulb could be burnt out, the rear dome is on the same fuse as the front map lights so if the maps work the fuse is good.
ASarsano is offline
post #4 of 5 Old 01-01-2015, 09:12 AM Thread Starter
brdgraf's Avatar
I will double check the cig lighters but I know that the one on dash is working. Thinking it may b a fuse also just can't figure out which one. Thx
AFE Pro dry intake
brdgraf is offline
post #5 of 5 Old 04-20-2015, 11:38 AM
GTinNH's Avatar
Quoted: 6 Post(s)
Any luck with this? I have the same problem
GTinNH is offline
