2015 xl manual windows to electric - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion (2011-2016) 6.7 Powerstroke Interior Discussion
post #1 of 5 Old 08-26-2019, 06:23 PM Thread Starter
I picked up a 2015 xl with 36k miles for a really good price to use as my work truck didn’t think the manual windows would bother me that much but it gets aggravating.... has anybody swapped in electronics on theirs I found some old stuff on searching nothing on the newer trucks. Can anybody point me in the right direction please
Lancha16 is offline
post #2 of 5 Old 08-27-2019, 02:05 AM
Quoted: 105 Post(s)
The problem is probably going to be the wiring within the dash and door. Do you have the wiring from the BCM to the driver door and do you have the wiring between the driver door and passenger door.
Here are the wiring diagrams. You can check the wiring in the kick panel areas to see if you have the colors going to each door plug or from the BCM to power the windows.
Name:	Power window 2.JPG
ID:	722307   Click image for larger version
Name:	Power Window 1.JPG
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #3 of 5 Old 08-27-2019, 02:45 PM Thread Starter
Thank you I was able to pull and see the wires to the passenger side and I do not have the wires so the truck is a 4 door I don’t know if that would matter I did find 8 wires going to the plug on the passenger side front door
Lancha16 is offline
post #4 of 5 Old 08-27-2019, 05:04 PM
Quoted: 105 Post(s)
You check the "B" pillow for the rear doors to see if they have any of the wires.
Name:	PW Passenger door connector 2.JPG
ID:	722385   Click image for larger version
Name:	PW CC 2.JPG
ID:	722387   Click image for larger version
Name:	PW Passenger door connector 1.JPG
ID:	722389   Click image for larger version
Name:	PW Any Cab Passenger side.JPG
ID:	722391   Click image for larger version
Name:	PW CC 1.JPG
Larry
post #5 of 5 Old 08-27-2019, 05:08 PM
Quoted: 105 Post(s)
and a few more...the rear doors are here
ID:	722395   Click image for larger version
Name:	PW Passenger door connector 3.JPG
ID:	722397   Click image for larger version
Name:	PW CC Rear doors.JPG
Larry
