Sloppy shifter adjustment?? - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion (2011-2016) 6.7 Powerstroke Interior Discussion
 1Likes
  • 1 Post By kaya
post #1 of 7 Old 04-11-2019, 11:19 AM Thread Starter
Quoted: 330 Post(s)
[s]I know how to adjust the old trucks’ levers, but I haven’t had a chance to look at how to adjust the slack in the shift lever for the 6.7. I got a fair amount of play in mine and want to tighten it up. It appears that nobody on the inter webs has the same problem as me...so does anybody have any insight on tightening up the gear selector on these 6.7’s?[/s]
Wrote this on mobile...Apologize for the rambling paragraph.
I would like to know if anybody has taken up the slack in the column gear selector, or knows how to in a 11-present Super Duty, as mine has a fair amount of play in it over the years. Can't be any more clear than that lol...
And allegedly, I don't know the code for strike-though anymore.
--H
2012 6.7
Too many toys for it to list
Last edited by HLBeef; 04-11-2019 at 03:56 PM. Reason: 1) Updated question 2) trying to get strikethrough to go thru, apparently not supporting BBCode (or I'm just getting old)
HLBeef is offline
post #2 of 7 Old 04-16-2019, 04:43 AM
Heavy_GD's Avatar
Quoted: 3044 Post(s)
Garage
Feedback Score: 3 reviews
@kaya @LoxDiesel ?
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #3 of 7 Old 04-20-2019, 06:47 PM
Powerstroke Techie
Quoted: 674 Post(s)
Pop the covers off and have a look. See if any of the clamp hold down bolts have come loose, or the bushings are worn.
I'm assuming they're at least similar to the 07 column. Though i don't know for certain, tbh.
HLBeef likes this.
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark.
-Michelangelo
kaya is offline
post #4 of 7 Old 04-23-2019, 05:40 AM Thread Starter
Quoted: 330 Post(s)
Thanks, kaya. I'll have to look this evening if I have time, haven't had a chance yet.
--H
2012 6.7
HLBeef is offline
post #5 of 7 Old 05-01-2019, 01:08 PM
Love all, Trust a Few...
LoxDiesel's Avatar
Location: If you go West and hit sugar cane come back a bit
Quoted: 1062 Post(s)
The shifter cable on the 6.7's is all grommets and clips, how much play would you say it has?
@loxdce
LoxDiesel is offline
post #6 of 7 Old 05-03-2019, 05:39 AM Thread Starter
Quoted: 330 Post(s)
It has about a quarter of an inch to 3/8" of play when its set down into a notch for a gear. It used to be tight and firm, but I have a bad habit of resting my hand on the shifter and I attribute that to shifter wear in all my vehicles lol.
--H
2012 6.7
HLBeef is offline
post #7 of 7 Old 05-03-2019, 09:49 AM
LoxDiesel's Avatar
Remove the lower cover on the column and you’ll see where cable hooks up. Check play there, then go from there
Sent from my iPhone using Tapatalk
@loxdce
Similar Threads
Thread Thread Starter Forum Replies Last Post
Sloppy Shifter Linkage chrisorbesen 94-98 7.3L General Powerstroke Discussion 4 11-08-2018 01:11 AM
7.3 trans shifter blinking engine revving in park or neutral 99f3504wdrestore Introductions 2 04-15-2017 08:25 AM
OFF blinking on shifter tonto13 94-98 7.3 Trannie Problems 2 03-17-2017 11:17 AM
Not cranking until I fiddle with the shifter mikew04f250 6.0L Problems Forum 3 12-23-2016 06:17 AM
Steering box adjustment on the 6.4? justinp95 General 6.4L Discussion 6 08-02-2016 06:59 PM
