Wind noise? - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion (2011-2016) 6.7 Powerstroke Interior Discussion
 6Likes
post #1 of 21 Old 10-11-2016, 12:06 PM Thread Starter
bogeyman's Avatar
Quoted: 9 Post(s)
Garage
Wind noise?
I am getting a lot of wind noise from the driver's side door. Anyone else?
I don't see anything obvious, but I am wondering if I can just replace the weatherstripping on the inside of the door frame?
bogeyman is offline
post #2 of 21 Old 10-11-2016, 04:34 PM
Quoted: 2 Post(s)
I had a similar issue on my 2016, and stopped by to see my body guy about it.
He said it is a common problem, then rolled down the window and gave a few sharp tugs to the upper window frame on the front door.
It wasn't a technical fix, but there is no more wind noise.
bogeyman likes this.
Avslash is offline
post #3 of 21 Old 10-12-2016, 05:53 PM Thread Starter
bogeyman's Avatar
Quoted: 9 Post(s)
Garage
We'll see what my guy does - I've made an appointment for the 24th.
bogeyman is offline
post #4 of 21 Old 10-12-2016, 06:36 PM
ZMANN's Avatar
Quoted: 3949 Post(s)
keep us posted please
i have the same issue on my 06 and have replaced all the weatherstrip but not the window seal since i couldn't even fit a business card through any place when the window was rolled up
i am starting to wonder if it is my new 08+ style mirrors when extended for towing or my hood deflector
but when i have my cab over camper on the wind noise is insane
6.0 flush pdf
ZMANN is offline
post #5 of 21 Old 03-13-2017, 08:18 PM
Quoted: 32 Post(s)
wind noise on these trucks has been narrowed down to the outer weather stripper lifting in a few spots at speed. I've upgraded all my door seals. Look on youtube for that mod. Its cheap and easy and makes a difference but the wind noise your talking about is likely the common outer upper little seal that is normally tight but at speed lifts ever so slightly to make a noise that sounds like a air leak somewhere. The fix is to put a bit of glue or tape on it to keep it down.
skycrane is offline
post #6 of 21 Old 03-13-2017, 08:35 PM
ZMANN's Avatar
that mod did not help me so i replaced my seals with new
6.0 flush pdf
ZMANN is offline
post #7 of 21 Old 03-13-2017, 09:40 PM
Gaius's Avatar
Quoted: 78 Post(s)
Zman, did your noise go away? My isn't very loud, but there.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is online now
post #8 of 21 Old 03-14-2017, 07:42 AM
Quoted: 26 Post(s)
Have any of you done the door seal mod where you pull surgical tubing through the void in the gasket?
HeavyAssault and john galt like this.
David Frost
2005 F250 Harley 6.0 CCSB
Towerguy is offline
post #9 of 21 Old 03-14-2017, 08:45 AM
ZMANN's Avatar
Sorry I shouldn't have posted in such a hurry
i have done the surgical tube on old and new door seals it just made the doors harder to close
the profile of a new seal vs an old seal with the tubing is completely different so while the tubing may help some
I still have the wind sound and the only seal left for me that is not new is the window seal and I am just not sure that's the issues since it is hard to slide a business card anywhere around the window seal
i also have window vent shades that attach to that seal so it may be them after all
I don't recall this sound before I did the 08 mirrors ?
i did remove my hood valance and even with the mirrors slid in I still have the wind sound
john galt likes this.
6.0 flush pdf
ZMANN is offline
post #10 of 21 Old 03-15-2017, 07:20 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 871 Post(s)
Feedback Score: 3 reviews
I found that there is noise from the 08-16 tow mirror light edges. Replacing the OEM with aftermarket styled ones there is an increased whistle that does present itself. Sometimes it is there, sometimes not. Concerning your issue; using blue tape you can cover up seams and gaps to help pinpoint the source. It does take time but it works.
Officially The Biggest Midget In The Game
HeavyAssault is offline
