Steering stabilizer single or dual? - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion (2017-2019) 6.7 Performance Parts Discussion
post #1 of 8 Old 01-19-2020, 08:17 PM Thread Starter
Quoted: 7 Post(s)
2018 F250 Lariat leveled with 37's, does everyone recommend a single in original oem location or dual setup. Also what brands(include part#) do you recommend?
Thanks
G2
Sent from my SM-G965U using Tapatalk
g2outfitter is offline
post #2 of 8 Old 01-20-2020, 02:59 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 945 Post(s)
Feedback Score: 3 reviews
OneUpOffroad has a pretty slick setup for a aftermarket single; OEM style single replacements are out there; Duals look cool and can do a good job as well.
How much can you spend??
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #3 of 8 Old 01-20-2020, 03:16 AM
Quoted: 19 Post(s)
I guess if I was buying another I would step up to dual while I was doing it
ehagerty is offline
post #4 of 8 Old 01-20-2020, 08:42 AM
Alberta Advantage's Avatar
Quoted: 86 Post(s)
I’m running a Carli levelling kit and got their OEM replacement single stabilizer. I’m running 35x12.5R20. My cousin has a BDS 6” lift and is using the same Carli steering stabilizer and he’s running 37x12.5R20 on his truck and there’s no slop in the steering wheel.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #5 of 8 Old 01-21-2020, 08:00 AM
Quoted: 10 Post(s)
I replaced my factory one with the FOX 2.0 Single. Its adjustable as well depending on how stiff you want it. It is pricey though.
Navion13! is offline
post #6 of 8 Old 02-01-2020, 11:56 AM Thread Starter
Quoted: 7 Post(s)
Well I ordered and recieved the fox 2.0 stabilizer for now and of course bad luck, it was missing the taper pin. And of course it was noticed after the old one was off. SMH
post #7 of 8 Old 02-06-2020, 05:40 PM
Jcismo1's Avatar
Quoted: 9 Post(s)
The Fox 2.0 ATS doesn’t use a “taper pin.” It uses a clamp that has 4 Allen bolts. I just installed this and I’m thoroughly impressed with it. What a difference!!
2018 F250 XL, 4x4, Ext. Cab, 6.7 P.S.
Jcismo1 is offline
post #8 of 8 Old 02-06-2020, 05:45 PM Thread Starter
Quoted: 7 Post(s)
Mine was not the ATS and it uses a taper pin. It definitely helped the truck as I got the replacement yesterday.
