HELP! Broke off egt probe tip in block plate! - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion (2017-2019) 6.7 Performance Parts Discussion
post #1 of 19 Old 09-19-2019, 04:38 PM Thread Starter
Quoted: 4 Post(s)
This is pre or post turbo? Am I an trouble here?? No limit EGR plate probe location .
gwalker is offline
post #2 of 19 Old 09-19-2019, 04:40 PM Thread Starter
Quoted: 4 Post(s)
It's gone or stuck somewhere. I am headed out early in the morning so need some advice please.
gwalker is offline
post #3 of 19 Old 09-19-2019, 06:16 PM
jetjock15's Avatar
Quoted: 330 Post(s)
Not sure what your asking? The egr delete plate is pre turbo. Not good if you lost some metal and it dropped down in there? Remove the plate and fish with magnet
19 F450
Iíve owned previous vehicles but I wonít waste the forum space to list them, oh ya, and you donít care
jetjock15 is offline
post #4 of 19 Old 09-19-2019, 06:21 PM Thread Starter
Quoted: 4 Post(s)
The tip (3.5") broke off inside the manifold somehow? It's been working for 2 months, all of a sudden this morning on my way to work it started reading egts that were not right so I drove it home pulled the sensor and the tip is gone!
If this thing gets to the turbo, im in trouble! Not sure how to get it out? I took the plate off and fished with a magnet as far as I could and nothing..
gwalker is offline
post #5 of 19 Old 09-19-2019, 06:53 PM
jetjock15's Avatar
Quoted: 330 Post(s)
Well if you drove home who knows? The right answer would be to pull it all. I’d put the magnet on a wire and try to fish it around way more than a little pointer magnet can do
19 F450
post #6 of 19 Old 09-19-2019, 06:55 PM Thread Starter
Quoted: 4 Post(s)
The real question is where did it go? Where can it go? Could it go in the head or through the turbo?
gwalker is offline
post #7 of 19 Old 09-19-2019, 07:25 PM
jetjock15's Avatar
Quoted: 330 Post(s)
Well its the exhaust manifold so not going in cylinder so your ok. Goes through the hot turbo wheel and out exhaust. So only thing at risk is your turbo. Donít see that probe passing through that without damage but maybe. Donít think all the exhaust goes through turbo? Have to google the routing
19 F450
post #8 of 19 Old 09-19-2019, 07:27 PM Thread Starter
Quoted: 4 Post(s)
Doesn't the exhaust come from the cylinder head into the hot side of the turbo? I was thinking it could fall in...?
gwalker is offline
post #9 of 19 Old 09-19-2019, 07:37 PM
jetjock15's Avatar
Quoted: 330 Post(s)
Oh i see your thought process. No it wouldnít go against the exhaust flow or get through the valve opening. Only thing at risk is your turbo from damaging exhaust wheel blades
19 F450
post #10 of 19 Old 09-20-2019, 07:33 AM
cmunsell's Avatar
Quoted: 3 Post(s)
Not sure if the image will post correctly. My bet if it somehow hasn't made its way through the turbo is it is stuck at the 'elbow' leading to the upper hot side on your turbo.
I believe this image is from a pre-'15 style turbo so the setup may not be the same.
cmunsell is offline
