P0402:Excessive Flow Diagnosis NO LIMIT INTAKE - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion (2017-2019) 6.7 Performance Parts Discussion
post #1 of 17 Old 07-17-2019, 06:28 PM Thread Starter
Seantsm2001's Avatar
Quoted: 8 Post(s)
Hey guys. Received my no limit stage 1 intake yesterday (we think it's a stage 1). I installed it last night and I drove it for about 2-3 hours today. The truck sat for about an hour getting the oil changed and tires rotated. When I drove it for about 15 mins the check engine light comes on. Went through the truck and everything was tight and good With the oil change. So I went by Auto zone to get the code read. It's P0402: EGR Excessive Flow Diagnosis. The truck is completely stock except for the intake. Why would the intake be pushing "to much air" in and the EGR reading excessive air flow. Besides taking off the $350 intake and waiting a few months before I completely delete everything and installing the stock intake, is there anything else that can be done? "IF" I have to install the stock intake will the code and engine turn off?. Thanks guys
Seantsm2001 is offline
post #2 of 17 Old 07-17-2019, 07:09 PM
Quoted: 303 Post(s)
Garage
I don't have a 6.7 so shooting in the dark a little here:
Have you checked the MAP sensor hose? maybe got knocked loose with the new intake
MAP sensor and Exhaust pressure sensor differential is used to calculate the "flow" of the EGR system
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 17 Old 07-17-2019, 07:20 PM Thread Starter
Quoted: 8 Post(s)
Thanks Hydro, what is and where is the map sensor
post #4 of 17 Old 07-17-2019, 08:05 PM
Powerstroke Techie
Quoted: 680 Post(s)
The pcm determines egr flow by monitoring maf.
Maf is an adaptive parameter that the pcm learns.
You need to have the maf tables reset with the new intake in.
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark.
-Michelangelo
kaya is offline
The Following 2 Users Say Thank You to kaya For This Useful Post:
Heavy_GD (07-18-2019)
post #5 of 17 Old 07-17-2019, 09:47 PM
Mr.Powerstroke1's Avatar
Quoted: 3 Post(s)
Garage
Cold air intake on 6.7
I am new on here. Just seen this post about CAI. I just order an S&B for my 2018 F250. I am wonder is this a common problem ..?
Mr.Powerstroke1 is online now
post #6 of 17 Old 07-18-2019, 01:27 AM Thread Starter
Quoted: 8 Post(s)
Kaya how do you have it reset. Thanks for the help
post #7 of 17 Old 07-18-2019, 04:36 AM
Powerstroke Techie
Quoted: 680 Post(s)
There are probably other interface tools capable; snap-on, launch, etc. But ids is what we use.
Toolbox>powertrain>service functions>reset/clear specific tables>reset maf sensor
-Michelangelo
kaya is offline
post #8 of 17 Old 07-18-2019, 04:39 AM
Powerstroke Techie
Quoted: 680 Post(s)
On these 17-19 trucks, maf is pretty highly monitored. There are at least six PIDs for it
-Michelangelo
kaya is offline
post #9 of 17 Old 07-18-2019, 05:42 AM
Treatcg's Avatar
Quoted: 60 Post(s)
Got a pic of the intake so we can make sure it isnít a stage 2?
Sent from my iPhone using Tapatalk
Clayton
2016 F250 6.7 FX4 Lariat Ingot Silver
2015 Jayco 267BHSW
Treatcg is offline
The Following User Says Thank You to Treatcg For This Useful Post:
post #10 of 17 Old 07-18-2019, 08:22 AM
Quoted: 3 Post(s)
Garage
Thanks, what is PID mean ?
