CP4 “disaster prevention kit” - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion (2017-2019) 6.7 Performance Parts Discussion
 5Likes
post #1 of 11 Old 03-04-2019, 05:31 PM Thread Starter
So this is my dilemma, I just bought a brand new 2019 f250 and i plan to keep this truck till the frame rusts through. Coming from older Cummins I’m new to the cp4. My current plans are fass titanium for obvious reasons but this is where I need advice. S&S diesel makes a cp4 “disaster prevention kit” or more properly named some type of bypass. For the 350 bucks I feel like this is a no brainer insurance policy but I can’t find any other major brands with something similar or any posts on any forms. Is this thing just a fluke or will it actually save the rest of the fuel system if the cp4 dies. Side note, any other tribal knowledge specific to the 6.7 PS to keep these things going and running like a top would be appreciated other than the normal preventative maintenance. Thanks
Bluebean598 is offline
post #2 of 11 Old 03-04-2019, 07:52 PM
Quoted: 21 Post(s)
I'm thinking the Achilles heel is the lubricity of diesel fuel. So I treat with Opti-Lube XL at 1oz to 10 gallons.
Time will tell...
HeavyAssault and Jcismo1 like this.
2019 Silver Spruce Lariat CCLB SRW F-350 FX4
Sport45 is offline
post #3 of 11 Old 03-05-2019, 01:20 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 687 Post(s)
Feedback Score: 3 reviews
The fuel pump on the newer truck is not a CP4.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #4 of 11 Old 03-05-2019, 03:13 AM Thread Starter
You would be correct, I just re-read there kit and since the road sodas wore off I see that it is 2011-2017 6.7 which in fact doesn’t include the new 2019 lol my apologies thank you buddy. (In a car pool for the commute to this job so I wasn’t driving just to be clear)
post #5 of 11 Old 03-05-2019, 04:38 AM
joebuck's Avatar
Quoted: 136 Post(s)
Ya I would run a good fuel treatment in every fill up and drain your separator regularly(free and cheap insurance to do) and just drive it!
2012 F350 CCLB Lariat/ EZ Lynk Tyrant tuned/deleted/15+turbo swap/No limit stage 2 intake/H&S silicone CAC pipe/5” exhaust/2.5” BDS Leveling kit on 35s/Fox shocks/20” XD grenades
joebuck is offline
post #6 of 11 Old 04-19-2019, 04:02 PM
85pickup4x4's Avatar
Quoted: 5 Post(s)
So I wanted to know more about this cp4 pump issue. I have been researching it, and learning alot. I'm looking at a 2017 or newer f350. Does the 17+ still have the same setup?? Did Ford come out with a new setup to prevent this issue????? I dont seem to be able to find any issues with the 2017+ fuel systems... Can someone shine some light for me. Thanks so much!
03 FORD 6.0 POWERSTROKE
S&B cold air intake
SCT 8900 with custom tunes
7" single smoker Exhaust stack
MKM's 6.0 powerstroke solution kit
-Sinister EGR delete
-FACTORY head gaskets
-ARP head studs
Sinister coolant filtration kit
ATS coolant return kit
EGT probe before the turbo
Boost builder
Fuel pressure regulator mod
6.4 Banjo bolts
Warn 8000lb winch
99 TOYOTA TACOMA
98 TOYOTA 4 RUNNER
85pickup4x4 is offline
post #7 of 11 Old 04-20-2019, 02:45 AM
N.S.D.Q.
Quoted: 687 Post(s)
Run a fuel additive, add a filter setup, buy fuel from high use pumps.
joebuck likes this.
post #8 of 11 Old 04-20-2019, 02:51 AM
Quoted: 192 Post(s)
They are all cp4.2s pumps.
HeavyAssault likes this.
SOOTIE is offline
post #9 of 11 Old 04-20-2019, 04:15 AM
Quoted: 5 Post(s)
Sootie, so the 2016 and older had the cp4? And the newer ones had the 4.2?? What did Ford improve on the newer one? Any cases of failure on the 4.2s??
S&B cold air intake
-ARP head studs
Boost builder
6.4 Banjo bolts
Warn 8000lb winch
99 TOYOTA TACOMA
98 TOYOTA 4 RUNNER
post #10 of 11 Old 04-20-2019, 06:26 AM
joebuck's Avatar
Quoted: 136 Post(s)
I know in the 15+ pumps got a bump in volume I think it flows 9% more than the 11-14s, but I’m pretty sure it’s the same pump other than that, I think the bigger issue is in the first few years they came out people read that they were made to run biodiesel and made to run the horrible ULSD we are fed these days so most didn’t use additives or drain there separators. Now i agree ford could have setup there system a bit better but people need to realize climbing under there truck for 1min to drain a small amount of fuel to make sure there’s no water in it goes leaps and bounds to save your fuel system and wallet. A lot of people have said “I shouldn’t have to lay under my brand new 70k truck” but guess what you do and if that’s to much for some then they shouldn’t own a diesel IMO buy a gasser. Buying fuel from higher turnover stations and reputable stations also helps as they “typically” have fresher fuel and hopefully maintain there underground tanks. But a good additive and a weekly,bi-weekly or monthly drain will save you a ton depending on your driving habits.
joebuck is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Additional fuel filters/disaster prevention kit broncobilly_69 General 6.7 Discussion (2017-2019) 5 10-17-2017 04:59 AM
2017 Theft Prevention - what's recommended 69machguy General 6.7 Discussion (2017-2019) 27 09-28-2017 09:08 PM
6.7L Disaster Prevention Kit? LowBoost General 6.7 Discussion (2017-2019) 11 09-25-2017 04:26 AM
