2011-2014 Turbo Kits master list - Page 6 - Ford Powerstroke Diesel Forum
 9Likes
post #51 of 63 Old 10-06-2015, 08:04 PM
Cheap6.7's Avatar
Cab on is fine.
Cheap6.7 is offline
post #52 of 63 Old 10-19-2015, 07:16 PM
[QUOTE=jcain;10016730]Feel free to post what I missed and I will add it or fix it.
Sunrise Ford (sponsor)
DIY 2015 turbo upgrade all OEM factory parts. (unconfirmed list)
turbo list $1719.05 sell $1237.72 w/exchange (core $250)
intake list $138.97 sell $100.06
downpipe list $152.92 sell $110.10
oil line list $31.63 sell $22.78
coolant line list $37.07 sell $26.69
shipping $25
Total : $1497.35 + the $250 Turbo Core
Does anyone have any part numbers for these? Found a few but not all. And also what base mount is the '15 kit? Thanks in advanced guys.
7.3 buggy is offline
post #53 of 63 Old 11-10-2015, 12:53 PM
BryanDowdy's Avatar
Quoted: 3 Post(s)
[quote=7.3 buggy;12559777]
shipping $25
Did you find out the part numbers?
BryanDowdy is offline
post #54 of 63 Old 11-10-2015, 06:55 PM
*BigBlack*'s Avatar
Quoted: 13 Post(s)
Garage
The list provided previously isn't the full list for the upgrade.
This is the complete list of parts to upgrade to the 2015 OEM turbo. The list was provided by fdny136 who upgraded. The pricing is Sunrise online pricing without discount.
FC3Z6K682A – Turbo - - - $1323.18
FC3Z9T514A – Gasket Kit - - - $42.28
FC3Z6N639A – Pedestal - - - $50.86
FC3Z9G437B – Exhaust Pipe (Right) - - - $14.52
FC3Z9G437C – Exhaust Pipe (Left) - - - $11.52
FC3Z6N646C – Down Pipe - - - $59.69
FC3Z8287A – Pipe Clamp - - - $12.55
FC3Z9B613A – Inlet Hose - - - $13.96
FC3Z6B689A – Oil Tube - - - $23.56
FC3Z9U469A – Water Outlet tube - - - $27.53
FC3Z9430B – Manifold (Right) - - - $50.62
FC3Z9424A – Inlet Manifold Assembly - - - $104.89
FC3Z9448A – Gasket (Right) - - - $9.62
FC3Z9448A – Gasket (Left) - - - $9.62
FC3Z9A462A – Heat Shield - - - $9.34
FC3Z9E464A – Gasket - - - $4.27
FC3Z9F459A – Tube EGR Valve - - - $32.70
FC3Z6N646A – Exhaust Pipe - - - $112.70
BC3Z9E464B – EGR Connector Tube Gasket - - - $3.06
Total online price $1916.47
Slamnslash, Castaway and Mossive like this.
*BigBlack* is offline
The Following 5 Users Say Thank You to *BigBlack* For This Useful Post:
BIG TEXAS STROKER (02-03-2016), BryanDowdy (11-11-2015), Castaway (12-02-2015), WORM5932 (11-22-2015)
post #55 of 63 Old 02-03-2016, 10:32 AM
BIG TEXAS STROKER's Avatar
Quoted: 2 Post(s)
Does anyone know if all these parts are needed if truck is tuned and has an egr delete kit? and the turbo being put in is a StreetMaxR not a stock 15 OEM turbo?
BIG TEXAS STROKER is offline
post #56 of 63 Old 02-04-2016, 03:58 AM
WORM5932's Avatar
I saw a list on Facebook for the deleted trucks. I personally would buy everything and take back what's not used
WORM5932 is offline
post #57 of 63 Old 02-04-2016, 09:18 AM
*BigBlack*'s Avatar
Quoted: 13 Post(s)
Garage
The parts would be the same for each turbo since mounting is identical. The only difference in each is probably the thrust bearing, wheel size, and the cover that is honed out on the streetmax. As to the actual parts, I believe you wouldn't need the Egr stuff but I'm not 100%. I would ask Morgan from Midwest or someone from River City Diesel since they both have kits.
post #58 of 63 Old 05-03-2016, 09:05 AM
barobbin's Avatar
Quoted: 4 Post(s)
FC3Z6K682A Turbo - - - $1323.18
FC3Z9T514A Gasket Kit - - - $42.28
FC3Z6N639A Pedestal - - - $50.86
FC3Z9G437B Exhaust Pipe (Right) - - - $14.52
FC3Z9G437C Exhaust Pipe (Left) - - - $11.52
FC3Z6N646C Down Pipe - - - $59.69
FC3Z8287A Pipe Clamp - - - $12.55
FC3Z9B613A Inlet Hose - - - $13.96
FC3Z6B689A Oil Tube - - - $23.56
FC3Z9U469A Water Outlet tube - - - $27.53
FC3Z9430B Manifold (Right) - - - $50.62
FC3Z9424A Inlet Manifold Assembly - - - $104.89
FC3Z9448A Gasket (Right) - - - $9.62
FC3Z9448A Gasket (Left) - - - $9.62
FC3Z9A462A Heat Shield - - - $9.34
FC3Z9E464A Gasket - - - $4.27
FC3Z9F459A Tube EGR Valve - - - $32.70
FC3Z6N646A Exhaust Pipe - - - $112.70
BC3Z9E464B EGR Connector Tube Gasket - - - $3.06
How would we go about getting the discount? and where is the best place to buy the towmaxr turbo?
barobbin is offline
post #59 of 63 Old 05-03-2016, 09:22 AM
barobbin's Avatar
Quoted: 4 Post(s)
Also, Why is the kit more expensive on midwest's website than buying the parts separately from ford? Are there pieces with the midwest kit that are not included in the above^^ list?
barobbin is offline
post #60 of 63 Old 05-04-2016, 04:34 PM
*BigBlack*'s Avatar
Quoted: 13 Post(s)
Garage
From what has been discussed on the army, the research, development, and trial & error on the kit is what you are paying for from a vendor. Multiple vendors worked together to put out these retro kits. The only vendor that has different parts is SPE and they just have a custom passenger side up pipe as opposed to replacing the manifold and up pipe with 2015 parts. Other vendors offer the same parts in their kits that I posted. I believe the vendor's kits come with instructions but if you review Jcain's review on the army and do a bit of research, you won't have to worry about the instructions if you are somewhat knowledgeable on motors. Mike at No Limit or Morgan from Midwest Diesel have been great to talk to. They are the best IMO on developing the 2015 retro swap. Midwest's tunes are the best for the Vgt style turbos because they were one of the lead shops to put out the retro swap. You can buy their tow max or their streetmaxR. Once you do either, you will run out of fuel from your factory pump to match your turbo. Good luck and feel free to pm Mike or Jeremy at No Limit, or myself. I posted a pic of my motor in my garage since I powdercoated my piping and turbo housing just to give you an idea of what it would look like with the piping kit.
