My last oil change I used Moible 1 Turbo diesel 5w-40 - Ford Powerstroke Diesel Forum
 2Likes
  • 2 Post By Left Coast Geek
post #1 of 8 Old 12-02-2019, 06:08 PM Thread Starter
Quoted: 7 Post(s)
Well, hopefully I did not cause any damage to my 2014 F 250 6.7 engine... I changed my oil recently putting Mobile 1 Turbo diesel 5w-40 before checking Fords WSS-M2C171-F1 specification sheet. I guess I would like your suggestions/thoughts if Mobile 1 5w-40 will cause any damage to my engine? I like Mobile 1 and have used it in my other vehicles but I did not do my homework and now I know it does not meet Fords WSS-M2C171-F1 specification....
Appreciate your thoughts.
whit66 is offline
post #2 of 8 Old 12-03-2019, 12:46 AM
Left Coast Geek's Avatar
Quoted: 140 Post(s)
Garage
Send a message via AIM to Left Coast Geek Send a message via MSN to Left Coast Geek Send a message via Yahoo to Left Coast Geek
I'd say just change it to an approved oil of the appropriate weight. unless you've put like 100K miles on multiple changes of the non-approved stuff, its not going to do any damage.
CJ-4 is low ZDDP (Zinc) so isn't as good anti-wear as older oils, fords spec attempts to address this.
2002 F250 Super Cab XLT longbed, white. stock except stereo and shell.
....old enough to know better....
Left Coast Geek is offline
post #3 of 8 Old 12-03-2019, 03:35 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 923 Post(s)
Feedback Score: 3 reviews
Ford's oil spec and approved list ONLY applies to using CK4 oils. CJ4 oils are always good to go. Mobil 1 bottles labeled as CJ4 are good to go, bottles labeled as CK4 need to be found on the list to be "approved".
Pretty sure you meant to say CK4.
Officially The Biggest Midget In The Game
HeavyAssault is offline
The Following User Says Thank You to HeavyAssault For This Useful Post:
whit66 (12-03-2019)
post #4 of 8 Old 12-03-2019, 05:16 AM
18M_RWR's Avatar
Quoted: 39 Post(s)
I'm sure most have found this search tool page that makes it easier than looking thru the PDF list for approved oils.
Search Diesel Motor Oils Meeting WSS-M2C171-F1 https://www.fcsdchemicalsandlubrican...archdiesel.asp
Makes it nice because you can fill-in any 1 of the 3 boxes and it will sort the approved list that way.
μολὼν λαβέ | si vis pa·​cem, pa·​ra bel·​lum
2016 F350 Lariat 6.7L CCLB DRW 4WD 4.30LS
14000#GVWR Pkg, HiCap-TowPkg, PlowPkg-ExtraHD Alt, WideTrack frt axle, Max frt springs
Sinister ColdSide Charge Pipe, OBDLinkMX+ MonitorApp on Fire7 tablet
18M_RWR is offline
The Following 2 Users Say Thank You to 18M_RWR For This Useful Post:
whit66 (12-03-2019)
post #5 of 8 Old 12-03-2019, 10:32 AM
Quoted: 140 Post(s)
Garage
errr, that right. 3am alphabet goes abcdefghikj....
HeavyAssault and Hydro like this.
post #6 of 8 Old 12-03-2019, 12:26 PM
N.S.D.Q.
Quoted: 923 Post(s)
No worries.
post #7 of 8 Old 12-04-2019, 08:08 AM
Quoted: 11 Post(s)
Even if the oil wasn't CJ-4, it's the proper viscosity and good, quality oil and running it until the next oil change isn't going to cause issues. On the next change use a CJ-4 or an oil from the approved list and don't look into any further and definitely don't worry about it.
druston is offline
post #8 of 8 Old 12-04-2019, 08:19 AM Thread Starter
Quoted: 7 Post(s)
Thank you druston, even an old man can learn things everyday!! I will use Rotella T6 in 5,000 miles.. Thank you again...
whit66 is offline
