Help Finding Part/Part Numbers - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-13-2019, 03:35 PM Thread Starter
CocainePlatinum's Avatar
Quoted: 7 Post(s)
I'm looking for the factory Hot Side intercooler Pipe Boots (the one on the turbo with the snap ring). I cannot find them anywhere. Maybe that's not what it's actually called ?
Any help is appreciated need to order the boots pipe not needed.
CocainePlatinum is offline
post #2 of 4 Old 11-13-2019, 05:02 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 871 Post(s)
Feedback Score: 3 reviews
PM me your VIN or use FordParts.com to get a close idea.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #3 of 4 Old 11-15-2019, 02:19 AM
Quoted: 105 Post(s)
you will probably have to call the dealer and ask them. Not sure if any of the Ford parts sites have these listed. Or, you might check to see if any of the aftermarket vendors have them listed.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is online now
post #4 of 4 Old 11-17-2019, 08:03 PM
Quoted: 34 Post(s)
Ford sells it as a complete pipe. The boots by themselves are not available from ford.
06 King Ranch
Fass 200, Custom fuel lines, 225/100s, Thumper stage 2 hpop, WPE stage 3 intake, Mishimoto radiator, Flex a lite fans, BPD water pump, MPD oil cooler relocate kit, Intercooler pipes, Compounds built by me, etc etc etc
05 Eddie Bauer
Resealed entire motor @ 170k miles, new lifters, 6.4 push rods, studs, rebuilt the turbo, IPR egr delete, new injectors, new heads, new ficm board, coolant filter, intercooler tubes, regulated return, bunch of other new parts. Factory exhaust, cat gutted(wife's rig). Livewire with gearhead tunes. Should go a while reliably for her!
03 LB7 duramax the "daily/tow pig"
Lbz cp3, s475/stock twin kit, built trans, steel driveshft, amsoil bypass, secondary oil cooler built by me, fass, traction bars, trans cooler upgrade, dual alts, straight center link + tie rod sleeves, efi live, transfer flow/tool box tank, 5er hitch, other small upgrades.. and most importantly, STOCK HEADBOLTS! Just rolled 200k miles, twins installed @ 165k, daily driven on a "550 tune" tows 18k on a "475" tune.
Nickjames525 is offline
