Airdog - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 7 Old 08-11-2019, 10:42 AM Thread Starter
Airdog
I put an air dog lift pump in my 2015 f350 yesterday and it ran fine for a few minutes then came up as a fault low fuel pressure. Now the truck will not start. I checked everything there are no leaks but the truck seems dry when I try to start it. I did the whole cycle it 6 or seven times to prime it. I even left it in the on position for 15 minutes still no juice any help would be appreciated
Tbabydad is offline
post #2 of 7 Old 08-11-2019, 10:57 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 952 Post(s)
Feedback Score: 3 reviews
Setting the key to the On position will only run the OEM fuel pump 30 seconds....after that it shuts off. You need to cycle the key Off then to On to get the OEM pump to run again....but only for 30 seconds.
Can you tell if the AirDog is running with the key cycled to On during that 30 seconds??
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #3 of 7 Old 08-11-2019, 11:27 AM Thread Starter
Ya the air dog is running and I've done the 30 second cycle a bunch of times so many times I'm charging my batteries right now air dog turns on runs good is primed as far as I can tell. After the pumps is done priming after thirty seconds there is a winning noise coming from the engine bay that doesn't stop as long as the key is on. Is it possible to get air in the high pressure side on a 6.7?
Tbabydad is offline
post #4 of 7 Old 08-11-2019, 02:08 PM
N.S.D.Q.
Quoted: 952 Post(s)
I don't think so without the motor running. Just cycling the key should be just the OEM and now Airdog running not the HPFP.
Did you install fresh OEM fuel filters at the same time??
post #5 of 7 Old 08-24-2019, 09:06 AM
Quoted: 38 Post(s)
Airdog is most likely vapor locked. Pull the filters off and fill them with fuel. Make sure never to run the tank below 1/4 otherwise you’ll suck air.
I truly don’t understand why people want airdog or fass pumps on these 6.7s. The 6.7 fuel pump supply’s more than enough fuel and the filters are killer effective. We run stock low pressure pumps on trucks with dual fueler kits.
Larry1013 likes this.
06 King Ranch
Fass 200, Custom fuel lines, 225/100s, Thumper stage 2 hpop, WPE stage 3 intake, Mishimoto radiator, Flex a lite fans, BPD water pump, MPD oil cooler relocate kit, Intercooler pipes, Compounds built by me, etc etc etc
05 Eddie Bauer
Resealed entire motor @ 170k miles, new lifters, 6.4 push rods, studs, rebuilt the turbo, IPR egr delete, new injectors, new heads, new ficm board, coolant filter, intercooler tubes, regulated return, bunch of other new parts. Factory exhaust, cat gutted(wife's rig). Livewire with gearhead tunes. Should go a while reliably for her!
03 LB7 duramax the "daily/tow pig"
Lbz cp3, s475/stock twin kit, built trans, steel driveshft, amsoil bypass, secondary oil cooler built by me, fass, traction bars, trans cooler upgrade, dual alts, straight center link + tie rod sleeves, efi live, transfer flow/tool box tank, 5er hitch, other small upgrades.. and most importantly, STOCK HEADBOLTS! Just rolled 200k miles, twins installed @ 165k, daily driven on a "550 tune" tows 18k on a "475" tune.
Nickjames525 is offline
post #6 of 7 Old 08-26-2019, 03:28 AM
N.S.D.Q.
Quoted: 952 Post(s)
First thoughts are the added filter capability. Second thoughts are they want to remove the lower OEM pump for some reason.
Some people just read too many magazines without thinking thru the modification making a better plan. Nothing wrong with running a low pressure AD to feed the OEM pump.
post #7 of 7 Old 08-26-2019, 11:22 AM
Quoted: 1468 Post(s)
Feedback Score: 4 reviews
Originally Posted by Nickjames525 View Post
Airdog is most likely vapor locked. Pull the filters off and fill them with fuel. Make sure never to run the tank below 1/4 otherwise youíll suck air.
I truly donít understand why people want airdog or fass pumps on these 6.7s. The 6.7 fuel pump supplyís more than enough fuel and the filters are killer effective. We run stock low pressure pumps on trucks with dual fueler kits.
I like the AD pump/filter on any common rail engine as any air whatsoever isn't good on any fuel system, especially any common rail engine.
The filters need to be filled up before install. I would bet that if you remove the filters there is no fuel in them. Watch Thoroughbred diesel's video on an AD or FASS filter change and it explains why you are having this issue. One thing that helps is that you top off your fuel tank so it doesn't take near as long to prime the AD/FASS type fuel pump setup.
I do agree the 6.7 factory pump is typically more than ample to supply.
HeavyAssault likes this.
