deleted egt probe? - Page 2 - Ford Powerstroke Diesel Forum
 3Likes
post #11 of 17 Old 07-08-2019, 02:27 PM
Quoted: 16 Post(s)
Go over mountain passes quite a bit,I feel a bit uneasy not knowing. I'd like to see oil pressure too. Can ya run just a monitor like say the edge display with some kind of aftermarket sensors? I have a sct x4 but I don't much about it. Can't find egt's on it and it bulky to use a monitor.
Oneops is offline
post #12 of 17 Old 07-09-2019, 03:07 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 819 Post(s)
Feedback Score: 3 reviews
I run the Insight CTS2 which has plenty of PIDs to view. Get little unit with expandable sensors that you can buy. Since OEM oil pressure is a switch you will need to run your own pressure sensor. To be honest oil pressure isn't as much a concern as are the temps. The PCM will shut down the motor on high oil temps long before oil pressure causes damage.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #13 of 17 Old 07-09-2019, 06:37 AM Thread Starter
Man there are some people on here with mucho knowledge,thanks for the insight
wa96stoke is offline
post #14 of 17 Old 07-09-2019, 06:55 AM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 600 Post(s)
Feedback Score: 11 reviews
the egr egt probe can be used with the block plates to give you pre turbo egts. doesnt read under 392, not sure what the max is as i havent seen over 1000 egts since deleting.
thats using an edge insight cts 2. the minimax comment is wrong.
HeavyAssault likes this.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #15 of 17 Old 07-10-2019, 06:27 PM
Durapig Eater's Avatar
Quoted: 163 Post(s)
I also use the cts with the expandable egr probe kit. Probe in the block off plate wired directly to the cts head unit an a suction cup stuck to the windshield. No troubles with this setup. Im tuned with the x4, to small of a screen and too clunky to monitor with for my taste.
I tried using the original egrt probe and the dpf egt probe in the block off plate and monitoring the egrt PID, did not work.
I have seen more oftentimes the trans fluid temp creep uncomfortably high than the egts when towing heavy.
HeavyAssault and bc_vickers like this.
Durapig Eater is offline
post #16 of 17 Old 07-11-2019, 06:30 AM
Quoted: 5 Post(s)
What's uncomfortably high if you don't mind me asking? I often tow a 32' horse trailer that can get into the 17-18k lb range and my temps are generally in the 21x at 80-90 ambient and then it's only for short periods of time.
bc_vickers is offline
post #17 of 17 Old 07-11-2019, 09:02 AM
Quoted: 163 Post(s)
Iirc 225+ pulling long grade trying to make miles so I don't have to park in the dark, so driving too fast for sure.
