Tyrant off-road tunes Performance vs Extreme - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-11-2019, 03:30 PM Thread Starter
Quoted: 4 Post(s)
I have recently acquired CEL codes p0401 and p20ee and also have noticed a decrease of power (posted in the problems forum), so i guess its the end of the road for my emissions systems.(YAY!!!) Anyway so i have done some research on tyrant and decided to go with the tow and performance tunes. But now i am thinking should i just go up to extreme instead? I am still on the stock turbo. The performance is 110hp and extreme is 130. Does anyone have any comparisons? Mpgs? Turbo boost psi? Difference in smoke? I want a little smoke but definitely not a 5.9 cummins smoke lol!
Powerstroke001 is offline
post #2 of 12 Old 05-15-2019, 03:54 AM
Phong6.7's Avatar
Quoted: 24 Post(s)
I have the ezlink with the sotf tune. 165 smokey tune sotf and the 155 clean tune. I can't tell any different from the extreme to performance. I just run it in extreme tune and turn down when i tow. I haven't try individual file yet.
Phong6.7 is offline
post #3 of 12 Old 05-15-2019, 03:18 PM
Quoted: 6 Post(s)
I have 60+ tunes from 4 different shops
My favourite is the Tyrant Extreme 210 tune (Dec 2018).
Run in my otherwise stock 2015 F350, with 5Ē Flo-Pro exhaust with muffler.
Great power and shifting and the best mileage of any Iíve tried.
08F350 is offline
post #4 of 12 Old 05-15-2019, 04:43 PM Thread Starter
Quoted: 4 Post(s)
Run in my otherwise stock 2015 F350, with 5” Flo-Pro exhaust with muffler.
Great power and shifting and the best mileage of any I’ve tried.
Thanks for the info! What kind of mpg do you see and what size lift/tire setup are you running? Looks like i may be going with the extreme tune, not that i will run the truck hard, but for the mpg. Have you ever compared it to the performance tune?
post #5 of 12 Old 05-15-2019, 05:18 PM
Quoted: 6 Post(s)
Iím getting between 21-25mpg between city and hi-way....I am usually easy on the go pedal.
No lift,
Running 35x12.5x18 Bridgestone TA ko2ís
Iíll run this tune while towing light and watch my egtís.
The 210 extreme tune is by far the best on fuel of any Iíve tried.
08F350 is offline
post #6 of 12 Old 05-15-2019, 06:43 PM Thread Starter
Quoted: 4 Post(s)
I’m getting between 21-25mpg between city and hi-way....I am usually easy on the go pedal.
No lift,
Running 35x12.5x18 Bridgestone TA ko2’s
I’ll run this tune while towing light and watch my egt’s.
The 210 extreme tune is by far the best on fuel of any I’ve tried.
What do you use to monitor and what kind of egt probe?
post #7 of 12 Old 05-16-2019, 05:42 PM
Quoted: 6 Post(s)
I use a GDP monitor with EZ Lynk
My EGR is deleted, you take one of the 4 stock egt temp probes out of your stock exhaust after you remove it, and put it in the block off plate when your egr is removed. You then have a egt to monitor.....and Bobís your uncle.
08F350 is offline
post #8 of 12 Old 05-17-2019, 02:02 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 767 Post(s)
Feedback Score: 3 reviews
@08F350 : What size fuel tank do you have? Crew Cab long bed?
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #9 of 12 Old 05-17-2019, 06:49 PM
Quoted: 6 Post(s)
I have the 26 gal tank
Crew cab, short box with tonneau cover.
08F350 is offline
post #10 of 12 Old 05-17-2019, 07:18 PM
Quoted: 22 Post(s)
Just installed Tyrant tunes on my off-road 16 F250 race truck, and HOLY MOLY!!!!
wreedPS is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Been Reading for towing with Tyrant Deleted Tunes 1badcj8 6.7 Performance Parts Discussion (2011-2016) 10 05-28-2019 08:59 AM
Tyrant Diesel DayTrader General 6.7 Discussion (2011-2016) 125 01-11-2019 08:18 AM
Parts coming in!! Question about Tyrant tunes!! jpw_07 6.7 Performance Parts Discussion (2011-2016) 8 01-09-2017 02:10 AM
Custom tunes?? bdog04pstroke 6.0L Electronics Discussion 7 07-26-2016 01:50 PM
