SCT X4 to EZ LYNK Questions - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-22-2019, 02:53 PM Thread Starter
Garage
What's the biggest differences between these two tuners? I am not going to do SOTF so is it worth me upgrading from the X4? Thanks in advance!
JJMassar is offline
post #2 of 4 Old 04-22-2019, 06:08 PM
Ez Lynk will potentially do SOTF as long as you have the box (cloud) plugged into your OBD ll port and you have a device connected to wifi. The ez lynk is WAY more advanced in monitoring than the x4. If you want to monitor your temps then the ez lynk is probably the way to go. If you want to just flash and go then the sct is a great device for that and is very versatile imo (you can also get an edge cts2 to monitor with either device). Now i am not sure about this, but dp-tuner recently told me that the SCT devices no longer support the uploading of custom tunes that delete emissions (dpf and egr systems) which supposedly comes in the new updates beginning in February. I wouldnt want anyone to purchase one without knowing the device is no longer delete compatible. I am still researching on this myself as plan to delete in the next few months but I already bought an x4 back in December but i updated it a couple weeks ago, so if what I’ve heard is true, my device will be up for sale.
Powerstroke001 is offline
post #3 of 4 Old Today, 06:20 AM
Quoted: 66 Post(s)
The downside to the EZ-Lynk, which nobody talks about, is that it operates through wifi. If you plan to use your EDC phone as a monitor, you cannot use cell services like calls, texting, or Pandora at the same time. You either need a dedicated wifi connection (separate tablet or old phone), or only turn on the EZ-Lynk app when you don't need those cell services.
The EZ-Lynk app does not need to run unless you want to monitor or change your tunes. Those are the only times I turn mine on. It is very convenient for tune updates though.
The SOTF does not need wifi. It's a hard wired connection.
2016 F-250 Platinum
EZ-Lynk, PPEI Tunes
Deuce40s is offline
post #4 of 4 Old Today, 06:29 AM
kafleming19's Avatar
Quoted: 919 Post(s)
Not true about ez-lynk, but I guess it could depend on your phone. My iPhoneX will connect via wifi and I can still have full functionality of the phone. The only thing I can't do is use the hotspot since I'm connected to a wifi device.
Kily AKA Lt. Axe
kafleming19 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
EZ Lynk auto Agent 2.0 Questions jdpate General 6.7 Discussion (2017-2019) 1 04-16-2019 06:00 AM
EZ Lynk AutoAgent 2 mrmanners Vendor Jungle 7 09-17-2018 10:04 AM
Question about EZ Lynk operation t.i.p. 6.7 Performance Parts Discussion (2011-2016) 13 01-31-2018 05:26 AM
EZ Lynk Problems - Customer Service kghenson 6.7 Performance Parts Discussion (2011-2016) 2 12-29-2017 08:08 AM
